water press. >
water press.
water press.
Old 08-18-2013 | 01:51 PM
Also, where is the pressure sensor normally located?
drpete3 is offline
Old 08-20-2013 | 07:31 PM
better pic
launchpad475 is offline
Old 08-21-2013 | 12:57 AM
not sure if you got my pm but im having the same problem with too much pressure. even with the overboard dump system I still have greater than 35 psi at 100mph. at 75mph the dump system looks like a water hose on high, think its 7/8in, but it still cant keep up. I have an imco sc lower lwp on my htm and going to try a reducer on the intake side of sea pump tomorrow. its a machined piece of aluminum that slides into the intake of sea pump. it has a small flange to not go to far into pump and reduces the about 1 inch hole on pump to about 1/2 inch. hopefully this will allow my dump system to be able to keep up with the excess water. even with the smallest crank and largest sea pump pulleys I had 7 psi idleing and around 35 at 90mph and about 37-38 at 102mph. gauge pegs at 35psi. like I said blow off was working but looked to be maxed out at top speed shooting a 7/8 stream past the outdrive at 75mph. I couldn't find a buddy to look at 100mph I think it will fix the problem, easier than welding up the intake on lower unit. ill be back! send me your email if you want some pics of the reducer. I have hell posting pics on here.
La/stryker is offline
Old 08-21-2013 | 01:09 AM
here lately my forehead but for the motor, mines on the front top where the thermostat would normally be. on the housing that sends water to each side of exhaust.
Old 08-21-2013 | 01:44 PM
posting reducer pic for la/stryker
Old 08-08-2014 | 12:04 PM
Originally Posted by Young Performance
You can either have a larger bypass installed or dump some water out of the rear of the intake, or where ever you can. I almost always run a dump from the rear of the intake. This not only dumps off excess water, but it also stop any steam pockets from forming in the rear of the intake and heads.
Where is your bypass installed?
Eddie
How about just a dump instead of a relief valve?
JRider is offline
Old 08-09-2014 | 06:51 PM
I put a restrictor in the in let of the water pump today. I'll see if it takes care of my pressure problem tomorrow. If it doesn't I am going to add a .375 dump out of my exhaust manifolds. I used a 3/4" pipe to 3/8" pipe bushing.
JRider is offline
Old 08-10-2014 | 07:38 AM
Id be cautious about limiting my flow into the pump, it may take the pump longer to prime. Aka, eat impellers faster.
Cole2534 is offline
Old 08-10-2014 | 08:38 AM
vintage chromoly's Avatar
I believe chocking the supply hose down will increase the pressure and decrease the volume. Not a good idea in my mind.
vintage chromoly is offline
Old 08-10-2014 | 09:02 AM
The orifice is about equal to an XR lower.
As far as increasing the pressure? Physically impossible. However, the velocity can increase through a smaller orifice.
JRider is offline
