whats truly needed to swap an ls engine
#161
Hey Precision, Keep me posted on that kit. I have a lot of experience on swapping wet joint exhaust to merc dry joint exhaust on regular SB chevy engines.. It a little more complicated than just bolting it on.. Not sure if it will translate to an LS or not but let me know if you are interested in the info.
[email protected]
Chris
[email protected]
Chris
#162
Really, all that effort in molesting your checkmate and going with carbs ??? What a waste when Holley has one of the best, & easiest to set up FI systems for LS motors money can buy!!! Your already there do it right for cripes sake !!!
#163
For the rest of you with positive interest in my little project, here is a little teaser pic of the 408ci LS2 mocked up for bracket manufacturing. I'll post more as I get it done and get my dyno numbers in the next couple of weeks.
#164
So your first post on OSO is coming in here to be a douche? I have an idea, when its your boat, you do what you want. As far as "molesting" my checkmate goes, there really isn't anything changed. I am wiring everything with a factory mercruiser plug, my headers exit at the stock location, and I only had to move my motor mounts slightly. If I feel like putting a stock Merc motor back in it, I can have it done in a weekend no problem. So until you know a little more about me and how "right or not right" I do ****, why don't you just go ahead and **** yourself.
Great pix and choice of technology till you get to the very top of the motor. I guess if you boat in OH where the chance of vaporlock is minimal a carb is fine. But go south or experience a lot of high humidity youll be wishing for a FI system.
#166
Only a 20yr old juvenile resorts to name calling when confronted with constructive criticism. Grow up kid open your ears and shut your mouth, you might learn something.
If he was a 20yr old and decided to use a carburetor I'd be even more impressed !
Too many 'kids', even those who know how to tune/install EFI, fall over dead when presented with a carburetor. Sounds weird, but that's happening all over.
If Corey331 is more comfortable with a carburetor, then that's his best choice.
Many of us here, work on and tune FI all the time, for work even, and yet some of us still use carburetors. Far from 20yrs old - and far from being stupid.
Corey - some of us like what you are doing. Carry on.
#167
The motor has actually changed a lot since those pics were taken. I got rid of that Demon carb for an AED prepped Holley HP 750, I added a nicer 3" K&N arrestor and I fabbed up brackets to relocate the coil packs to the back of the cylinder heads to keep the motor clean looking. i am currently milling up a bracket to keep the water pump housing from spinning, so once that's on in the next week or so, I'll update with new pics. I also got my alternator mounted and am using a heim joint tension-er to keep that belt tight. As far as power steering goes, I am doing some experimenting there. I'll post up what I did IF it works, which it should.
#168
I think your use of the term 'molested' is what got Corey fired off...and deservedly so.
#169
I guess somebody hasnt been around boats long enough to have heard of all mercs FI vapor lock horror stories...
