No fuel pump provision on motor >
Old 08-17-2013 | 10:21 PM
Get a holley or equivalent marine pump and regulator. Just call the pump manufacturer they will recommend a pump for your carburator and give you basics on how to set the fuel pressure regulator
sparky24 is offline
Old 08-18-2013 | 03:22 PM
BUP
Just for the record 4.3 / 262 CID V-6 , 5.0 / 305 CID, , 5.7 / 350 CID - V 8 small blocks marine engines all had electric fuel pumps on carb engines.
Not one of these motors thru out the whole 2000's used a mechanical fuel pump. Volvo penta and Mercruiser. both used electric fuel pumps for the past x amount of years.
. I want to say all electric fuel pumps started around 1997 or 1998 for the small blocks and even earlier for the V-6. As of late no more carb engines from the OEM stock marine manufacturers. FYI
BUP is offline
Old 08-18-2013 | 03:32 PM
vintage chromoly's Avatar
I have a practically new Mallory marine electric fuel pump I'd sell if that helps you.
It's the lower psi carb version.
Pm me if you want.
vintage chromoly is offline
Old 08-18-2013 | 03:52 PM
Merc fuel pump cross reference
[ATTACH=CONFIG]506492[/ATTACH]
[ATTACH=CONFIG]506493[/ATTACH]
[ATTACH=CONFIG]506494[/ATTACH]
Attached Thumbnails No fuel pump provision on motor-pump1.jpg   No fuel pump provision on motor-pump2.jpg   No fuel pump provision on motor-pump3.jpg
phragle is offline
