Inverted oil filter on  496 ho  engine? >
Old 09-08-2013 | 08:23 PM
I have the 496 I have been poking a hole, but I heard of the loosen it up and it will drain also. Once I have fresh oil in the motor I pull the lanyard switch and turn the motor over a few times to get oil pushed back up then put the lanyard back on and fire it up get pressure right away.
BIGBREW is offline
Old 09-09-2013 | 01:09 AM
Originally Posted by 26sonic
do you poke the hole before draining the oil or during ?
It doesn't really matter. I do when I start so it has a longer time to drain out.
Use filters with an anti drainback for the reasons posted by Sydwayz.
Griff is offline
Old 09-09-2013 | 01:18 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally Posted by BUP
Do not poke a hole in the oil filter, unsrew it a couple turns just before it leaks oil out. let it sit overnite while you drain the motor oil out the oil drain hose - next day the oil filter will be empty on its own.
Been doing it this way for years and never a drop spilled. Usually loosen it 1st thing then pump the oil out. By then the filter has already drained. wait awhile then finish pumping rest of oil out. No more tools required or modified to punch holes. What about the debris the filter caught? Have you not now made a passage way for the debris to reenter the oiling system by punching the filter?
But whichever way tickles your fancy is ok with me
US1 Fountain is offline
