Captains Call Exhaust Issue >
Old 09-10-2013 | 09:25 AM
Originally Posted by 07DominatorSS
Batteries are probably weak. I had the same problem. Have the batteries load tested. They may need to be replaced.
Agreed. But this shouldn't be an issue if the engine(s) are running.
Cole2534 is offline
Old 09-10-2013 | 10:19 AM
I've had mine NOT stay open with the engine running on dead batteries, FYI
Good luck
Hook'em is offline
Old 09-14-2013 | 10:37 PM
OK, beautiful day on the water, but still having issue. I was able to turn switch to thru hull, then manually put into thru hull position. I then put in two brand new batteries, and nothing changed, still had to manually put into thru hull position. Now the Port side stays locked in the Thru hull position when the switch is turned off. Everything appears to be securely connected/ no loose wires.
geaux is offline
Old 09-15-2013 | 12:59 AM
You need to use a multimeter to see if power is getting to the solenoids.
Griff is offline
Old 09-17-2013 | 07:32 AM
Are you running in salt or brackish water? Reason I ask is that this may contribute to corrosion of the diverter components in the exhaust. I would disconnect the solenoid from the lever and see if the butterfly moves freely on the pivot rod. If not, you may have to pull the diverters and disassemble the butterflies, and clean and lubricate everything.
Budman II is offline
Old 09-17-2013 | 05:15 PM
Mine got stuck last year, Move the rubber boot out of the way, get a little high temp grease and put a tiny bit on your finger and put it on the slide that goes in and out of the solenoid, open and close them a few times by hand to grease the inside of the solenoid a little bit, put a tiny bit more on your fingers and lube that slide again. Make sure that rubber boot covers the area it is supposed to. Then try your button and see if it works, you may have some corrosion in there that is creating enough resistance to keep them from working.
BIGBREW is offline
Old 07-02-2024 | 08:01 PM
Default Did you ever find a solution for this? I am having the save issue.
I realize this is very old post, but did you ever find a solution for this? I am having the save issue after installing new solenoids. Worked great for a minute, then went dead. Holds open if I push them open manually…
Sulley is offline
Old 07-02-2024 | 10:24 PM
did you use the new springs or original?
boatnt is offline
Old 07-02-2024 | 11:04 PM
I figured it out - all I had to do was hit the red reset button near the back of the engine. Not sure why that happened, though. Seems to work great now. Will have to water test to be sure…
Sulley is offline
Old 07-03-2024 | 07:40 AM
Having not seen any pictures of the system or the schematic just be aware that some solenoids have a pull and a hold coil inside of them. I have switchable tips. One pos to pull and another hold. Apples to bananas but sometimes due to low voltage or a mechanical drag they won't pull without "help" but will hold if helped in correct direction.
BadDog is offline
