Quick Question.....Winterizing 496 H.O. >
Old 09-13-2013 | 10:16 PM
Default Quick Question.....Winterizing 496 H.O.
I have winterized my 496 H.O. the last couple years with out an issue, My boat goes in a garage below the frost line that keeps it above 40* all the time. I always put Sta-Bil in my fuel, My question is, Someone told me to put a couple of ounces of 2-cycle oil in the gas to lubricate the seals in the fuel pump over the winter, not a problem, How much 2-cycle oil do I use?? I think I probably have about 40 gallons of fuel which I hope to burn down a little tomorrow for the last ride of the year.
BIGBREW is offline
Old 09-13-2013 | 11:06 PM
Rwbrew3's Avatar
Your better off filling it completely up to prevent condensation/moisture !! Not sure about the two stroke oil... I would drain all water, fill fuel tank, add addative, then cover her up !!!
Rwbrew3 is offline
Old 09-13-2013 | 11:29 PM
My boat goes in a garage that is below the frost line so it does not get the change in temperature. I drain the fuel to almost empty, treat it and fill it in the spring with the good stuff. I do drain all the oil and fill with fresh, fog the cylinders and fill the block with anti freeze even though I can just pump out the block and let it go if I wanted to take the chance, I take good care of this motor, just heard of the 2 cycle oil trick this week, just looking for info.
BIGBREW is offline
Old 09-13-2013 | 11:58 PM
Rwbrew3's Avatar
Gotcha.... Hopefully someone will chime in who has done or heard of this !!
Rwbrew3 is offline
Old 09-14-2013 | 12:13 AM
I stopped at my local marina to get a water/fuel separator and he told me this, he said it lubes the seals in the fuel pump using the 2-cycle oil, just a couple ounces, He may be right, I don't know, but it sounds like it make sense that is why I am asking.
BIGBREW is offline
Old 09-14-2013 | 12:37 AM
Randy Nielsen's Avatar
Just an observation, a couple of ounces to how much fuel? I have rebuilt many outboard carbs that gummed up from letting fuel/oil mix set over the winter. Plus if your not using ethanol the fuel in the system with stabilizer should keep the seals from drying up. Imho. Randy
Randy Nielsen is offline
Old 09-14-2013 | 01:03 AM
I probably have 40 gallons in the tank, I will put Sta-Bil in the tank, but I heard add a couple ounces of 2 cycle for fuel pump seal lube, I have never heard of that, that is why I ask.
BIGBREW is offline
Old 09-14-2013 | 05:05 AM
imo,2 oz of oil in 40 gal of fuel will do nothing for the seals,or anything else.think about it,5280 oz of fuel and 2 oz of oil.
mike tkach is offline
Old 09-14-2013 | 05:51 AM
Too Stroked's Avatar
You should not "fog" a fuel injected engine by dumping fogging oil into the air intake. (That's a technique used for carbureted engines.) The two stroke oil suggestion is a technique to safely "fog" a fuel injected engine by getting oil into the engine via the fuel path.
Too Stroked is offline
Old 09-14-2013 | 06:44 AM
If you have a choice, and can store your boat with pure gas in it (non-ethanol fuel) I would do it.
johnny b good is offline
