Need Help With Cable Replacement >
Old 09-18-2013 | 10:45 AM
Default Need Help With Cable Replacement
I am hoping someone can help me with this. I need to replace the shift cable from the shifter to the shift bracket on a Fountain Fever 27. This is my first time working with this kind of setup. The question I have is can the cable be removed from the shifter without pulling the shifter off the console. Second how do you remove the cable end from the shifter? I have been told that the cable end is a plastic “hook” that clips onto the shifter. And lastly does anyone know the length cable I will need for this boat? I wanted to pre order the cable so I can do the removal and install at the same time rather than removing the old cable and measuring it. I have been told that the cable itself is a 33c type. Thank you everyone very much for the help. Everyone on this site has been very helpful!!
GoFast28 is offline
Old 09-18-2013 | 11:05 AM
Should be numbers on the cable that correlate with the length. Most likely have to remove shifter. Not a hard swap though
Crude Intentions is offline
Old 09-18-2013 | 01:12 PM
97FASTech's Avatar
Veteran: Army
This may help, click and open with adobe:
[ATTACH=CONFIG]508220[/ATTACH]
97FASTech is offline
