gen 6 engine filling oilpan with water.
#42
you said it had the problem with the iron head and now has it with the edelbrocks. is there any chance there is some strange core shift with the block or machining that has put a water port between the block and heads in an odd place that allows the water to seep past the head gasket? just throwing things out there.
#43
when it came to me with the origional heads one was cracked and i thought that was the problem with the water intrusion.before i had any machine work done i had the block magged and it was good.im going to do some more checking tomorrow but im sure il be taking the heads off soon and im really going to check how the head gasget lines up with the block and head.
#45
#46
i did not think this was the problem but WE HAVE A WINNER.i tightened the bolts to the point of almost snapping them and ran it again,i put dye in the cooling system to help find the leak,NO MORE LEAK.i took the manifold off and checked it for flatness on both sides with a straight edge,it is warped.it is a competition products that is made in china.im either going to get it milled straight or replace it with a new american made peice depending on the owners wallet.id like to thank all you guys for your ideas on this.
#49
I had a procomp intake for a sbf that was machined so crooked that you could rock it back and forth on the engine. I just sent it back and bought an edelbrock. I try my best to never use chinesium crap as I have had so much of it fail or have spent too many hours trying to fix it before I can even use it. at least you found it so you dont have to pull all your hair out now.
#50
this is the manifold that was on the engine when the owner bought the boat.im going to do my best to talk him into buying a new american made one and i dont want the old one,even for free,chinese junk.
