454mag top end rebuild >
Old 04-24-2014 | 08:56 AM
  #181
Rookie's Avatar
I went to my local hydraulic shop and picked up steel fitting that was 1/2x20 thread and O'ring seal on one end and female 1/4" NPT on the other. I then just bought a 1/4" NPT male / 3/8"barbed brass fitting. I went with the straight barb as opposed 90° barb so the hose would rest on the bilge floor. I then ran ~6' of hose up to the front of my bilge. The ball valves shut off the oil and separate each engine.
Rookie is offline
Old 04-24-2014 | 02:15 PM
  #182
Thanks fo rthe info. Heading to my local hydraulic shop in the morning.
ramos45 is offline
Old 04-24-2014 | 08:03 PM
  #183
Rookie's Avatar
I did medium loctite the fitting into the pan.
Rookie is offline
Old 04-25-2014 | 11:28 AM
  #184
so I'm thinking I rathe have a 90 degree over to the center stringer and the run the hoses forward to a y connector then one hose up to the pump. here's what I picked up this morning for the bottom of the pan.
[ATTACH=CONFIG]522572[/ATTACH]
ramos45 is offline
Old 04-25-2014 | 12:18 PM
  #185
Rookie's Avatar
Yes, that's what I was talking about. Secure the hoses and loctite in the pan.
My first engine had an issue priming the pump.
Rookie is offline
Old 04-25-2014 | 12:29 PM
  #186
yea, priming may be a concern once it's a permanent fixture in the boat. at home on the bucket i just poured some oil into the hose before tightening it up on the dip stick. that little pump can really pull. sucked out brand new 20-50 cold oil through dipstick.
ramos45 is offline
Old 04-25-2014 | 03:37 PM
  #187
Rookie's Avatar
Fyi, the inside of the inlet and outlet port is 3/8" NPT so just pick puck 2 barbed fitting that are 3/8 NPT male. (didn't know if you knew that)
If anyone wants to know the pump we are referring to.
http://www.harborfreight.com/12-volt...ump-94639.html
Rookie is offline
Old 04-25-2014 | 03:42 PM
  #188
Yea, the OD is 3/8 npt and OD is 3/4 garden hose. I used the garden hose side while at home. I will use the npt side for suction when mounted on boat probably.
ramos45 is offline
Old 04-25-2014 | 03:54 PM
  #189
From the link above:
Compact and lightweight, this self-priming 12 V pump is ideal utility pumping around your home. Pumps water at up to 300 GPH (gallons per hour). Clips onto 12V battery terminals.
•Stainless steel pump housing
•Maximum flow: 300 GPH (gallons per hour)
•Total head lift: 35 ft.
•Dual threaded inlet and outlet:
•Includes mounting bracket
Not for use with fuel or flammable liquids.
How long do you think the seals will last when used with oil?
dbkski is offline
Old 04-25-2014 | 03:57 PM
  #190
Not sure, but going to find out. when they die I'll open it up and see if I can replace. For the one/two oil changes per year I'll try it out.
ramos45 is offline
