Thinking of running a crossover >
Old 10-31-2013 | 01:27 PM
Thanks! I learned something today....always a good thing.
Padraig
Padraig is offline
Old 10-31-2013 | 03:30 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Originally Posted by Sunrocket24
Now that's what I'm talking about!! Very beautiful clean looking engine Deep!!! My engine looks like a freaking Octopus right now!
So it looks like you also have Gils? So do you just run from the thermostat to bottom of manifold and then manifold to riser up top?
Thanks for the compliment . Yes , from the thermo housing to the exhaust manifolds then to risers . I do not run a thermostat . Water temps run 100* or so consistently and oil temp stays at 190* + a couple when lake water temps rise . 13 seasons and never a problem . Does take a lil bit to get the oil temps up . My setup is from Keith Eikert . Good luck with your project .
the deep is offline
Old 11-07-2013 | 11:11 PM
Looks like KE doesn't offer the thermostat/diverter housing you have. Any idea of anyone who sells something similar? The CP kit one looks hideous IMO. Thx
Borgie is offline
Old 12-01-2013 | 06:30 PM
glad I found this thread, I'm in the same position. Replacing my old 454 330 hp with a carburated 502 mag rebuilt to stock specs. I boat in fresh water and do lots of low speed cruises and idle quite a bit. Stock bravo drive and my boat used to be a salt water boat and also has a through hull fitting that has a valve and a pump that says "aerator" what are the pros and cons of running a bypass, which do you recommend and should I add a sea strainer?
stimleck is offline
Old 12-02-2013 | 12:30 PM
I have a well built 524 and I'm running a crossover with a 160 thermostat. I idle for long distances and the temps are dead on. I would definitely run a bypass with a thermostat, of course I boat in some very cold water. I don't use a sea strainer, but the water I boat in is crystal clear. If your boating in murky water or like to pull up to beaches, I would recommend the sea strainer.
ThisIsLivin is offline
Old 12-03-2013 | 11:04 AM
Would the crossover be beneficial on a small block with an Alpha??
CC230 is offline
Old 12-03-2013 | 11:14 AM
Dave M's Avatar
Veteran: Navy
I love my sea strainer if for no other reason than making it real easy to flush the motor. No more muffs!
Dave M is offline
Old 12-03-2013 | 12:35 PM
If its a stock rebuild, then run a stock recirc pump. A sea strainer is always good, especially if you boat in shallow areas with weeds, leaves, etc.
No.
Griff is offline
Old 12-03-2013 | 12:39 PM
the deep's Avatar
Fast Singles Club
You will free up a couple ponies and rid yourself of a little weight but it will not be enough to gain any appreciable speed . It does go a long way in cleaning up the engine for appearance purposes . I had one on my 383 stroker .
the deep is offline
Old 12-06-2013 | 10:21 AM
Thanks for the reply The Deep, I guess the question is, will the pump in the Alpha be enough to keep it cool?. I'm also building a 383 and yes it would be nice to clean up the mess on the front!
CC230 is offline
