Merc alt terminals >
Merc alt terminals
Merc alt terminals
Old 08-14-2002 | 05:23 PM
mopower's Avatar
Toxic FORMULA
Cord, I still have the stock arrangement that doesn't seam to charge ENOUGH at an idle (at night).Daytime its fine 2000rpm at night it's fine. Just idling in no wake zones at night is the problem. Thats why i'm going to lager , single wire alts.
mopower is offline
Old 08-14-2002 | 06:00 PM
Lee's Avatar
Lee
Originally posted by mopower
Merc mechanic I know sez attach the 10 ga. output wire to the output terminal and just tape and tie back other wires. They're just not use with single wire applications. I want to put larger ones on my Formula 272. At night with lights and bilge blowers on and even a high idle I'm still under 12 volts. Turn on the dock lights or plug in the 29 gazillion megawatt spotlight and things really go down the tubes
Rev it up over 1800 RPMS after you start it. Merc alternators won't star charging until it sees that RPM.
Lee is offline
Old 08-21-2002 | 08:55 PM
NASTY HABIT's Avatar
thanks for the input....
B = Battery (output)
EXC = exciter lead to switched ignition
S = non switched ignition (battery hot )
L2 = not needed
P = not needed
E = not needed
I think........
NASTY HABIT is offline
Old 08-21-2002 | 09:50 PM
Official OSO boat whore
I believe that merc also installs a ground. Not really sure if it's needed though...
Cord is offline
Old 08-21-2002 | 10:21 PM
I was going to just hit the alt housing with a ground .... should work shouldn't it ?
techman
Fountain
1
07-07-2008 06:48 PM
BadDog
5
06-02-2007 05:02 AM
Anarchy Powerboats
05-22-2006 10:15 PM
aTX427
4
06-21-2004 06:51 PM
kook
23
06-26-2002 07:58 PM
