Cam shaft numbers >
Cam shaft numbers
Cam shaft numbers
Old 01-30-2014 | 08:50 AM
  #121
Originally Posted by cstraub
Bill,
John Fenton, the previous owner of Canfield Heads, was the one that made a comment about your port work, it was not me Bill.
thats an out and out lie.and learn to spell Tom's name correctly con man.
sutphen 30 is offline
Old 01-30-2014 | 08:51 AM
  #122
Sir,
I haven't slipped back nor do I pretend to be a cam guru. Your coming to your own conclusions.
Remember this? Got called out for peddling chitty cams, much like your previous recommendation in this thread, and then pull the "who me, I never said I was an expert"
Quit dropping names, and crawl back under your rock. Should I be impressed that you know that I had two blocks machined at CNC three years ago? It was posted in another thread on this forum.
HaxbySpeed is offline
Old 01-30-2014 | 08:54 AM
  #123
Bill,
You being an accomplished engine builder and tuner you should not need my cam specs.
Chris
thats right liar,I like my engines to make improvements in speed.
buthet,you spred lies about zones motor blowing up when in fact its still runs after 11yrs.
Old 01-30-2014 | 08:55 AM
  #124
Originally Posted by sutphen 30
come on liar straub
maybe you want to talk about a cylinder head of canfields,that was destroyed by your cam,dropped a valve.but the best part of the lie is when you said John and you were talking and that I was the one that fixed it.liar that you are,you spred lies about me fixing said head,even though I was in the hospital at the time.and for a fact,canfield was the the one that actually fixed the head.but you spred the lie about me anyway.
as for the cams in those blower motors,again,I was not around to spec them so Tom field a cold call from a con man and let you do them.
boat befoer cams ran 92mph,better heads,cam and such,ran 91mph.nice cams you speced.
Bill,Bill,Bill,
Your are correct, the heads were shipped back to Canfield for repair, thats when Fenton got to see your port work. The call I got was for lifters, remember "Drag Race Lifters". I think Crane, Comp, Isky, Lunati, and several companies all have different level of lifters but they are not designated for an application. A solid roller lifter is used in a solid roller application Bill. It's up to the person buying the lifter what they want to spend.
cstraub is offline
  #125
thats how he does it,cold calls everyone and buddies up to them to gain info on all sorts of stuff,,the typical MO of a con man.
Old 01-30-2014 | 08:59 AM
  #126
Bill,Bill,Bill,
no no you drunken clown,,you,thats right,you sold the lifters to Tom.they had oiling problems to the top end,caught that screw up by you on the stand.all 5 sets.see,the truth never changes,still the same story from me.all the way back to 2005.try to lie correctly con man,
your chitty cam broke a valve.
the heads you fool were when I was out on a medical.So again oh brain dead one,as much as you want it to be me,,it wasn't.so for the last time oh liar,,stop spredding a lie.end of story.
Old 01-30-2014 | 09:02 AM
  #127
Expert, Guru, I don't have an ego that needs to be stroked so I don't use those labels. My customers go out with my stuff and win championships, period. Just this month a well respected engine builder called me, I about fell out of my chair as he has been around 40 years, called to tell me he had several of my cams on his dyno and was impressed with all of them. I did a marine blower cam for him this week.
I don't think we have ever met, what is your first name?
cstraub is offline
Old 01-30-2014 | 09:04 AM
  #128
bill,
So not enough guide clearance on a blower motor application is the cams fault.
cstraub is offline
Old 01-30-2014 | 09:17 AM
  #129
I don't think we have ever met, what is your name?
Brian Orlandi from Orlandi Performance, I do not want to meet or do business with you.
I have had the opportunity to replace 2 of your cam "recommendations" over the past 3-4 years so that the customer could run wet exhaust and mufflers. Both made more speed (= + TQ ...you know the thing that makes boats go faster) after the change. They also lost the impressive docking in gear stumble/stall problems.
brian41 is offline
Old 01-30-2014 | 10:03 AM
  #130
I take it you guys are all business people... Don't you have anything better to do than throw stones at each other? What is someone that is new to this forum or never been on it before gonna think if they come across this thread? If you are professionals at what you do then please show a little professionalism.
Black Baja is offline
