Cam shaft numbers >
Cam shaft numbers
Cam shaft numbers
Old 01-30-2014 | 11:15 AM
  #141
Originally Posted by cstraub
Brian,
If you google search myself, Straubtechnologies.com, or custom camshafts the only negative about me is from the same people posting on 1 forum. I've had many customers that they have read that thread and after doing so and reading between the lines they call me. Many of them engine builders.
Chris
Bull chit. your nightmares are everywhere from the Corvette forum to every marine forum. If anyone searches any offshore forum, they will find nothing but complaints. the 2 sites where your "buddies" live are the only 2 that have a good thing to say about you, but hey, when you sell them parts at or below cost, they will say anything to keep the deals coming.
Zone 5 is offline
Old 01-30-2014 | 11:18 AM
  #142
Bill,
You being an accomplished engine builder and tuner you should not need my cam specs.
Chris
You are right, he doesn't need your crap. My boat gainned ELEVEN mph after HE redid the motor. It ran for the 7 years I owned it, and now after 11 or so, its still running with the new owner. Yet you tried to claim on THIS forum that it blew up.
Zone 5 is offline
Old 01-30-2014 | 11:19 AM
  #143
Originally Posted by Black Baja
Hey Chris who is grinding your cams?
Andrews, Bullet, Clay Smith, Crane, Demos, GS, and Isky.
IOW, the same people you or I or anyone can call to get a custom cam done.
Zone 5 is offline
Old 01-30-2014 | 11:21 AM
  #144
Brian,
Chris
Went to your site and had visions of Fred at Trick Marine. Please by all means show us your business property with all its equipment, inventory and hired help. It must be a monster taking up several square miles of real estate to house all the BS you offer. I see you have your own line of AFR heads.......thats impressive why have I never heard of them? Does AFR actually put your name casted in the heads?
brian41 is offline
Old 01-30-2014 | 11:26 AM
  #145
I thought the same thing. But hey, at least he paid a pretty good web designer to do the site.
Note that he stocks none of that stuff. Wal-Mart couldn't afford to have that. almost everything he sells is drop shipped.
Zone 5 is offline
Old 01-30-2014 | 11:27 AM
  #146
Originally Posted by Zone 5
Someone new? If they read this hopefully they are going to see that almost 100% of straub's marine cam picks don't work as claimed.. Hopefully they will go elsewhere and not get the shaft (no pun intended) as so many other people have.
Ask straub how come one of his acclaimed cams couldn't get the boat beyond 4000 with a 19p prop. Ask him why he speced a cam for a specific engine and boat, and then when it wouldn't run, he told teh guy he needed to buy new heads. I'm sure he is going to come up with so BS about this, but the benefit of the internet, is that the true stuff is all out there if you look.
All he does is drop names, and then thinks he is impressive because he calls us by our first name. Here is a hint. Every person on this thread that he has called by name knows he is a fraud, and wishes he would stop pretending to know us by calling us by name.
Doug,
I have nothing to hide. I post my real name. I have a real business that is growing. My customers are happy, mfg, engine builders and retail, and I am crucified if I dont' say who I am dealing with and the reverse if I do.
Again Google is your friend.
cstraub is offline
Old 01-30-2014 | 11:34 AM
  #147
Brian,
I deal with multiple cylinder head companies as a Vendor/Customer basis.
cstraub is offline
Old 01-30-2014 | 11:35 AM
  #148
I guess the 200 sets of Morel lifters here are "vapor lifters"
cstraub is offline
Old 01-30-2014 | 11:39 AM
  #149
WOW. impressive. you have lifters in stock. you have all this stuff in stock too?
AN Fittings
AN Wrenches
Battery Boxes
Braided Line
Bolts and Fastners
Bronze Distributor Gears
Cam lock plates
Cam Buttons
Camshafts
Carb Parts
Degree Bushings
Gaskets
Guide Plates
Ignition Parts, Modules/Caps
Lifters, OEM
Lifters, Aftermarket Roller
Oil Pans
Oil Restrictors
Oil Pump Primers
Poly Locks
Retainers, Steel and Ti
Rocker Arm Balls and Nuts
Rocker Arm Studs
Spark Plug Wires
Starters
Stud Girdles
Timing Covers
Timing Pointers, Billet
Valves
Valve Locks, 7, Super 7, 10 degree
Valve Springs
Wheel Studs
Wheel Screws
Zone 5 is offline
Old 01-30-2014 | 11:40 AM
  #150
Wow if this guy dropped panties as fast as he dropped names he'd be hangin with Ron Jeremy instead of dicking around on here! Oh and it's Bobby Carrita btw
Unlimited jd is offline
