Cam shaft numbers >
Cam shaft numbers
Cam shaft numbers
Old 01-29-2014 | 11:39 AM
  #71
johnnyboatman's Avatar
I only said I got the heads from mike, because he didn't or do I remember the head numbers and they're not near me at the time, yes I figured big heads, big ci, big cam, big carb meant it would make big power excuse me for asking what other people's cams were. Like I said I went from a set of blown 557s to a set of n/a 557s I figured they would produce atleast 700hp but they didn't and I was just trying to see if my motors compared to others build sheets or specs were close or way off . I'm just going to let this thread go I'm over it trying to ask, I've got a call in to bob so I will leave it at that. And as for the heads I got from mike they're great I didn't say anything bad about them other than they may be to big for my application .
johnnyboatman is offline
Old 01-29-2014 | 11:44 AM
  #72
Originally Posted by cstraub
And most of my engine builder customers have that along with a full shop to do the work needed to make the numbers the engine needs to make. Some have multiple dyno and huge R&D budgets like ATK North America.
You are nothing more than parts salesperson with ZERO knowledge or ability....years of your BS prove that. As far as polesmoker goes his video tells his story better than anything I could come up with to discredit him.
brian41 is offline
Old 01-29-2014 | 11:46 AM
  #73
OP came to his senses........... nothing more to see
brian41 is offline
Old 01-29-2014 | 12:20 PM
  #74
SB
Haxby, quick question, are you still selling some AFR's ?
SB is offline
Old 01-29-2014 | 01:31 PM
  #75
You are so mis-informed sir. The OP is right, this forum use to be great for shared knowledge.
cstraub is offline
Old 01-29-2014 | 03:20 PM
  #76
As long as the people sharing it know what they are talking about. People quoting 107 cams for wet exhaust clearly don't
Zone 5 is offline
Old 01-29-2014 | 03:21 PM
  #77
He can't be Didn't some big shot tell him that he would make sure he couldn't get them?
Zone 5 is offline
Old 01-29-2014 | 03:32 PM
  #78
This is he OP's POST:
Just curious what's everybody running for a cam in 540 and larger ci 700plus hp N/A
Can you diagram the sentence to show me where it states Wet Exhaust?
cstraub is offline
Old 01-29-2014 | 04:34 PM
  #79
SB
True.
He didn't state if he had a car with a 3500 stall converter, 3.73-4.11 gears, and what the car weighed either.
Come on man, this is Offshore Only. So....an offshore boat probably with a Bravo drive.
Would you run this cam with an I/O driven BOAT and say dry exhaust even?
SB is offline
Old 01-29-2014 | 04:49 PM
  #80
True.
Scott Birmingham, how are you? That cam in the 540 would idle at 450 rpm. It had 12" vacuum at 900 rpm. Based on its power out put and power range and how its manners were it would work in a marine application with dry exhaust. At 83 degrees of overlap you could not run that in wet exhaust.
cstraub is offline
