Electric Fuel pump Q? >
Old 02-11-2014 | 06:54 PM
Default Electric Fuel pump Q?
What electric fuel pumps or you guys running on a 500 hp motors? What after market pumps like, Holley, areomotive, magnafuel, Mallory, etc..... And I quess the biggest Q is or y'all running marine pumps or regular pumps?
Mike S. is offline
Old 02-11-2014 | 07:23 PM
Any reason you don't want to run a mechanical pump? Are you EFI?
For a 500HP engine, the Mallory marine electric pump and regulator is a reliable setup. I would stay away from the holley red/blue style pumps.
MILD THUNDER is offline
Old 02-11-2014 | 10:00 PM
Gen 5 block! And yes I was EFI but im rebuilding the motor and I'm going to carb set up!
Mike S. is offline
Old 02-11-2014 | 10:08 PM
just use the fuel pump thats on the sea pump..
FIXX is offline
Old 02-12-2014 | 07:47 AM
I thought about that! Wasn't sure it was a good idea but I don't see why! If it's got enuf psi for EFI it's got enuf for 6-8 psi!
Mike S. is offline
Old 02-12-2014 | 09:32 AM
Since you were thinking you needed to go electric,I think you should spend a little of that money on a new replacement pump for the existing rwp driven one ....Motor is fresh ..Pump should be also ...JMO
motor is offline
Old 02-13-2014 | 02:55 PM
Craney's Avatar
What's better a electric or mechanical fuel pump?
Craney is offline
Old 02-13-2014 | 03:04 PM
I prefer mechanical myself.
Old 02-13-2014 | 03:35 PM
My Gen VI 454 block has the manual pump mounting boss. Need to check if cam has the lobe on it. Do you have to run a bronze or brass tipped fuel pump pushrod with the billet cams? Thought I read that somewhere.
Budman II is offline
Old 02-14-2014 | 04:43 PM
big advantage of mech pump; engine quits, pump quits. you can't fill the bilge with gasoline. at least not nearly as likely. that is probably the main reason for the rwp driven lift pump for efi. it is the closest thing to absolute fuel cut-off.
dereknkathy is offline
