Cam suggestions for 383 build
#81
Lunati has this one. Looks interesting. How would it very from say the 212/218 @.050 112 LSA
Hydraulic Roller. Good idle. Largest cam recommended for power brakes. Stage 2 cam, excellent street performance and off road use.
•Advertised Duration (Int/Exh): 284/284
•Duration @ .050 (Int/Exh): 218/218
•Gross Valve Lift (Int/Exh): .492/.492
•LSA/ICL: 112/106
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: Idle-5500
•Includes: Cam Only
•LSA/ICL: 112/106
•Includes: Cam Only
#83
#84
Okay, I called Lunati and asked about the single pattern cam I had posted and they highly recommended the 211/219 @112 and said it works really well. I guess I'm down to that cam or the comp 264 which has nearly the same specs. Again, what kind of top rpm's can I expect from the comp 264 in my 383 with better flowing GLM manifolds and would it be of any benefit to go with stainless risers over stock risers?
#86
[QUOTE=38special;4088576]Okay, I called Lunati and asked about the single pattern cam I had posted and they highly recommended the 211/219 @112 and said it works really well. I guess I'm down to that cam or the comp 264 which has nearly the same specs. Again, what kind of top rpm's can I expect from the comp 264 in my 383
Still dead at 4000rpm
#87
#88
I think this cam from Summit has the same spec as the cam in the 6.2 MX merc engine
http://www.summitracing.com/parts/crn-104224
#89
#90
A day away from payday and I'm still flopping around. Lol I did get a hold of Muscle marine here in Kansas and he said he has several cams that will work. One that will for sure make 350 h.p. and A 400 h.p. cam which he said would likely be more like 370 h.p. out the prop.
