Rebuild 575 SCI's and add closed cooling system >
Old 03-23-2014, 06:04 PM
Originally Posted by Vinny P
Yes, the original t-stat housings are in good shape. Maybe Johnny would let them go if someone needed them.
I cant wait to fire these engines up. It should be soon.
These are for Johnny Sonic 358?
4bus is offline
Old 03-23-2014, 08:06 PM
I hate the winter!!
Vinny P's Avatar
Yes they are for Heres Johnny's 358
Vinny P is offline
Old 03-28-2014, 06:09 PM
Offshoreonly Advertiser
Mbam's Avatar
Vinny very nice work! It is possible you will need a re-cal on the ECU depending on the temp it will hold. I am a staunch believer in closed cooling, been running it since 1983 or so.
Can you tell me the part number of the T stat housings? I want to check something.
Mbam is offline
Old 03-28-2014, 06:22 PM
I hate the winter!!
Vinny P's Avatar
Marc,
Here are the part #'s I used.
housing 861188a1
cover 807075a1
As far as re-cal of the ecu's, I dont think it will be necessary. I used the stock 142* t-stats. I am very confident that this heat exchanger can handle these engines. I have actually used this same heat exchanger on another bigger cubic inch engine package, making considerable more power. The temps on that engine stay within a few degrees of the t-stat.
Vinny P is offline
Old 03-28-2014, 06:58 PM
wayne272's Avatar
Great job, looks good.
wayne272 is offline
Old 03-28-2014, 08:59 PM
Mbam's Avatar
I was just trying to figure out the water flow but it looks like you have it handled - again, great job!
As far as temp that is good news. Only thing about the blower motor is that it creating more heat than a NA motor of the same power. I used to be able to tell you how much more but I can't remember. Maybe 20%? I seem to remember brake specific numbers close to .6 for the blower motors. NA is roughly .5
Mbam is offline
Old 03-29-2014, 05:29 AM
I hate the winter!!
Vinny P's Avatar
Marc,
I agree about blowers creating heat. However, with the exception of having to go .030 in the bores, these engines have not been modifed at all. I have only seen the boost guage hit 3 psi at wot. Hopefully, not enough to matter.
Vinny P is offline
Old 03-29-2014, 02:32 PM
I hate the winter!!
Vinny P's Avatar
I got the stb engine completed today. The plumbing was a bit of a nightmare. There is just not enough room to run all the hoses. Now that I have one engine done, the other should go easier.
Attached Thumbnails Rebuild 575 SCI's and add closed cooling system-p3290486.jpg   Rebuild 575 SCI's and add closed cooling system-p3290487.jpg
Vinny P is offline
Old 03-29-2014, 05:29 PM
Vinny, awesome job and for all the great info !! Rob
ezstriper is offline
Old 04-01-2014, 04:57 AM
https://www.youtube.com/watch?v=or5J...LYTLFK2EU4kEBw
https://www.youtube.com/watch?v=BBuT...LYTLFK2EU4kEBw
https://www.youtube.com/watch?v=Ezgw...LYTLFK2EU4kEBw
Here's Johnny is offline
