Why this cam in a 420? >
Old 03-25-2014 | 08:28 AM
I'm not positive, but did your boat come from Illinois? If it is the boat I am thinking of, I thought at one point it had small superchargers. Either way, that cam sucks.
Honestly, I had one of those 402 Formulas. They are friggin tanks. I had around 600HP per side, and a 25P 4 blade netted me around 5400RPM, 70mph in some chop and trimmed out. That was full roller engines, Dart aluminum heads, stellings headers, 5lbs of boost.
I think a 23P prop is too much for that boat, even if you had true 420HP engines. Get the engines in good health, and I think you're gonna end up with some 21P, or even 19P 4 blades. With 400HP merc's, those boats ran around 55mph at best. Try some 21P Merc Revolution 4 blades. My 402 liked those props the best. Planed great, good cruise, and good top end.
MILD THUNDER is offline
Old 03-25-2014 | 09:14 AM
Hi Mild, yes that is the boat. The engines were changed before I bought it and were supposed to have had the top ends freshly rebuilt. They were in reality thrown together with left over parts, mismatched junk. 41 mph when I got it home. tore into one engine last summer (during boating season at the dock) redid heads worn seals, guides, weak springs. different style rockers ect. threw it back together to salvage the end of the season. Now I'm having the other heads done and replacing everything on both of the top ends. I did get it to 50 mph last fall. I will be happy to see 55-57 once done. Derreberry Performance is doing the heads and once I get them back together I will start playing with the props. I am thinking someone took some mags and threw in whatever they had laying around and threw them in the engines.
chris302 is offline
Old 03-25-2014 | 09:30 AM
Right on!! Takes balls to freshin up a motor at the dock !! (;
mcprodesign is offline
Old 03-25-2014 | 11:53 AM
Originally Posted by Griff
Real 420 cams are Crane 132561 and are readily available
Griff, you know better. lol. http://www.offshoreonly.com/forums/g...-vs-440-a.html
The original 420 is a Ultradyne cam but you are right the Crane cam is a close substitute and after talking to Bob I was very happy using it in a motor I built a few years ago.
As for the Crane being readily available,
Summit - Estimated Ship Date: 4/15/2014 (3+ weeks)
Amazon - Not available
Jegs - is down now but the last time I checked was weeks also.
and I wouldn't trust any of them to ship when they say they can. I waited a couple months and then canceled my order when I found one on eBay (new in its original box, almost wanted to keep it for nostalgia reasons).
f_inscreenname is offline
Old 03-25-2014 | 12:00 PM
The 420 was a crane cam. The 440 was a ultra Dyne.
Old 03-25-2014 | 01:35 PM
I Already have the cams and the gold rockers. got them from carshop.com in stock and less than the others but shipping is a little more.
chris302 is offline
Old 03-25-2014 | 01:38 PM
Not balls just a thin wallet. It was either pay someone to pull the engines or buy parts.
chris302 is offline
Old 03-26-2014 | 07:58 AM
Cool. The carshop seems to have better prices on some stuff than summit and the others.
Do you know if your engines are original to the boat? Wonder what size intake valve they have in the heads?
Old 03-26-2014 | 12:24 PM
Mild, they are not original located previous owner and was told he bought a 1989 357 and swapped the motors before he sold the 402 im going to measure the intake valves this weekend whenI get back to the lake
chris302 is offline
Old 03-30-2014 | 10:16 PM
Ok just got back from the lake the intake valves are 2.19
chris302 is offline
