Why this cam in a 420? >
Old 03-31-2014 | 10:45 PM
Ok so I'm guessing not only did the engines not only not have the top ends freshly rebuilt, as advertised, But they are 365's NOT 420's Fi_ick me!
chris302 is offline
Old 03-31-2014 | 11:19 PM
Nice. Always good when someone slaps engines together, with some $hit cams, those were $hit btw, mismatched rockers, etc.
You do have the forged domed pistons I hope, and not the dished 330 pistons?
MILD THUNDER is offline
Old 04-01-2014 | 07:56 AM
The number on top of the pistons are 14097021
chris302 is offline
Old 04-01-2014 | 07:57 AM
Originally Posted by chris302
23 pitch mirage 3 blade,also tried hydromotive 23 4 blade no change
You couldn't turn rpm so you added MORE prop?
4bus is offline
Old 04-01-2014 | 08:34 AM
When I first got the boat I had the 4 blades sitting around and tried them. Issue was top rpm port engine 4450 starboard 4100. I should have the engines back together next couple weeks then I can start figuring out the props.
chris302 is offline
Old 04-01-2014 | 09:05 AM
Did you find anything obviously wrong with the engines when you tore them down, besides the conservative cam?
I agree with thunder, that 21p is prob where you will end up, even 19p if you want to spin those new cams up to peak.
**sorry, just read your post above about mismatched parts, good luck to you. Now you will know what you have, and peace of mind.
4bus is offline
Old 04-01-2014 | 07:19 PM
Originally Posted by Griff
Real 420 cams are Crane 132561 and are readily available
I bought 2 of them so I agree
welfare racing is offline
Old 04-01-2014 | 11:08 PM
Hi4bus No reason to be sorry I RRRRealy am greatfull for all the assistance I get. It has been 30 years since I built motors, and back then it was small block cars not big block boats.
chris302 is offline
Old 04-03-2014 | 11:00 PM
Sooo the next question is is the advance curve different 365 to 420. I'm hoping to fire one engine up next week. I have the advance curve for the 420.
chris302 is offline
