Bravo 3 tilt switch R&R
I have troubleshoot that my bravo tilt switch is not working. The gauge switch is fine but the drive will not go up with the up button. I have to use the trailer button.
I see according to the documentation that the drive has to be removed to change out the switch. Also, I see that the puck comes apart and you can access the wires in the puck. Can't I just unscrew the puck screw in the into the new puck and adjust as needed?
2nd option
I can see the bolt that is holding the 2 half moon pieces of the wire with the drive down and turned to the starboard side. On the inside I see where the wires are coming in the transom. Can't I just remove the bolt and replace the switches as needed, adjust each puck and be done?
Is there any disadvantage in doing it this way?
2nd option
The "correct" way to do it is to remove the drive to gain access to the wires where they run through the transom. You can however cut and splice the wires. Use some some butt connectors with the shrink built in and you will be fine. Dont take them apart. Once you replace it, adjust it so you get six inches of travel and that should get you in the ball park.
Btw bypassing this will allow the drive to be trimed like the trailer button..so keep a eye on your trim gauge..
