Glue for bunk carpet?? >
Old 04-15-2014 | 07:23 PM
Smitty's Avatar
Default Glue for bunk carpet??
I am putting all new bunk boards and carpet on my trailer. The carpet I bought has a rubber backing and says it can be glued down. I am also going to be using stainless steel staples. Question is, who knows what glue to use ????
Thx
Smitty
Smitty is offline
Old 04-15-2014 | 08:07 PM
Sydwayz's Avatar
Forum Regulator
[ATTACH=CONFIG]522071[/ATTACH]
Just average outdoor carpet glue has worked for me.
Source from Lowes, Home Depot or the like.
Slather it thin on the face of the 2x6s with a plastic putty knife.
I've had the same quart for years but it's pretty well dried up now.
Sydwayz is offline
Old 04-15-2014 | 08:45 PM
I used 3M spray adhesive.
ICDEDPPL is offline
Old 04-15-2014 | 10:58 PM
Rubber backed carpet?? Not sure if I would use it.
f_inscreenname is offline
Old 04-15-2014 | 11:52 PM
97FASTech's Avatar
Veteran: Army
Originally Posted by icdedppl
i used 3m spray adhesive.
x2
97FASTech is offline
Old 04-16-2014 | 12:19 AM
Thats a good point that , rubber backing doesn`t last long when wet, it starts to fall apart.
ICDEDPPL is offline
Old 04-16-2014 | 01:02 AM
What Sydwayz said, outdoor carpet glue from hardware store. Did mine last year, troweled it on.
ramos45 is offline
Old 04-16-2014 | 09:15 AM
Knot 4 Me's Avatar
I've never used glue. Don't see the need for it. Pull the carpet good and tight and Monel staples. Never had an issue with the carpet shifting or coming loose.
Knot 4 Me is offline
Old 04-16-2014 | 03:27 PM
Smitty's Avatar
The carpet is made specifically for bunks. Same stuff Heritage used when they built the trailer. I am going to glue the face that hits the hull and then pull it tight and wrap 2X6 and staple under edge.
Smitty is offline
Old 04-16-2014 | 08:48 PM
eightsecmopar's Avatar
X3....3M spray adhesive and stainless staples
eightsecmopar is offline
