need help to set  rpm wire >
Old 05-01-2014 | 01:35 AM
Default need help to set rpm wire
I install est ignition but when I connect rpm wire from the coil to the GAY wire engine stop running ( my boat mercusier )would some one tell me what wrong and how to make tach work thank.
tk350 is offline
Old 05-01-2014 | 06:45 AM
Ayuh,.... If the motor dies from hookin' up the tach, odds are the tach, or it's wire is a dead short to ground,...
Bondo is offline
Old 05-01-2014 | 08:06 AM
today I go find down I may run wire from tach to coil and see what up next thanks.
tk350 is offline
Old 05-02-2014 | 08:41 AM
Default found problems
[QUOTE=tk350;4115345]today I go find down I may run wire from tach to coil and see what up next thanks.[
thanks I was found out problem the tach wire was connect to ground .
tk350 is offline
Old 05-02-2014 | 09:29 AM
[QUOTE=tk350;4115971]
Ayuh,.... That'll do it,...
Bondo is offline
