Water Cross Over >
Water Cross Over
Water Cross Over
Old 08-19-2002 | 01:40 PM
ragtop409's Avatar
Question Water Cross Over
Hi me and a budy are putting a Pro Charger on his 7.4 whe pit the water cross over on and now wonder do whe put the thermast back in the new thermast housing that replaces the big Merc. one with 7 lines on it. Any I deas from people with water cross overs would be great THANKS Charlie.
ragtop409 is offline
Old 08-19-2002 | 02:16 PM
Official OSO boat whore
It may take some work to get the system to function correctly, but start with the stock thermostat and 3 3/16" holes drilled in it. And yes, you'll need a aftermarket thermostat housing. Get one with the bypass.
Cord is offline
Old 08-19-2002 | 10:30 PM
I put on crossovers and tstat housings with a 5/8in restrictor in them this spring oil temp is good with about 110 to 120 water temp water press is 20lb.
fstboater is offline
Old 08-20-2002 | 03:50 PM
blown formula's Avatar
140 degree thermostats are available from West Marine......
in the cooler water of Washington, a thermostat may be needed. Procharger does not recommend a thermostat! If you call them, register your charger serial # and ask for a install manual that is specific to your engine......you will get it fedex in 3 days, no charge!!
blown formula is offline
mcrsr
10
09-30-2005 09:33 PM
dyno
10
02-17-2004 08:43 PM
rssteiny
7
10-21-2003 08:33 PM
GNJ2
2
05-28-2003 01:16 PM
Joe Hetterich
3
05-15-2002 10:17 PM
