baja to a sea ray >
baja to a sea ray
baja to a sea ray
Old 05-18-2014 | 07:47 AM
Default baja to a sea ray
sold my outlaw 24 to go to a sea ray 210 bow rider (my kids like the bow rider).the sea ray 210 has a 5.7 engine and the top speed is 45 mph, i would think that the boat should do 50+ mph . the engine has 199 hrs and runs great 19 p mirage on it.is this all i am going to get out of this boat ?
mikeoutlaw24 is offline
Old 05-18-2014 | 08:08 AM
vintage chromoly's Avatar
The drive is too deep for high speed running. It's set deep for stability.
vintage chromoly is offline
Old 05-18-2014 | 08:19 AM
it is also set deep to fit under the engine cover. but try a 21 prop.
dereknkathy is offline
Old 05-18-2014 | 08:21 AM
Ayuh,.... Trimmed out, 'n Flyin',..?? At what Rpms,..??
Bondo is offline
Old 05-18-2014 | 09:07 AM
is that a 2 barrel 5.7 ? if so go to a performer intake and carb, you getting 4500-4600 ?? but those are NOT performance hulls..
ezstriper is offline
Old 05-18-2014 | 09:25 AM
I used to have an Ebbtide 210 with the same 5.7 Carb. I ran a Mercury Laser II SS prop, 21 pitch and I was able to run low 50s.
MonkeySea2 is offline
Old 05-18-2014 | 09:40 AM
For comparison, I had a searay 190. It had a full roller (cam, rocker arms) ported gt-40 heads, port matched dual plane edelbrock intake, holly 650 (completely worked) 10 to 1 compression and thru hull pipes. 350 horse or so.
The boat topped out at 53 on the gps.
The prop shaft was 6.5 below the keel.
I was running a 17" stainless 3 blade mercury prop and a pre alpha drive (1.5)
Old 05-18-2014 | 04:40 PM
53 with 17 inch prop? you were winding it to near 5500.
Old 05-18-2014 | 04:56 PM
Yes I was. Mid 5000's topped out! 5600 or so max. I tried a 19" but didn't have the torque to spin the bigger prop with so much propshaft depth.
Old 05-19-2014 | 10:25 AM
http://www.ilmor.com/en/marine/performance/MV8-570.aspx
Put this in it..
Pismo10 is offline
