O2 sensor without drilling and welding Lightning headers
#31
I thought the sensors heated up on their own. I'll pre-empt this by saying that I have zero experience with O2 widebands, so I'll defer to those who have tuned with them. I just recall reading that the water ruins them after they have heated up, and I think EZstriper mentioned waiting to supply power to his sensor until he know it would stay dry.
#32
Did a little Googling and answered my own question:
"If there are unburned combustion products but also oxygen molecules in the exhaust, the combustion products rather combine directly on the electrode surface with the oxygen in the exhaust instead of the oxygen coming through the ceramic without creating a voltage. So even though there is fuel there, the sensor will read as if a lean condition exists. These sensors require a minimum temperature of about 300C to work. Single wire sensors relied solely on the heating by exhaust gas. At idle that may not be enough. Multiwire NBO2 sensors have a built-in heater that helps keep the sensor at operating temperature at idle and also speeds up the heat up process to minimize open loop startup time. "
From: http://www.innovatemotorsports.com/resources/news3.php
#34
I plan on trying out the pipe this week. At least I would like to see what kind of flow i get thru the pipe and how hot it gets.I just ordered my AFR gauge and sensor this Monday morning so I am hoping to see it one day this week.
#36
Correct me if I'm wrong, but i could swear 02's measure outside exhaust 02 vs inside 02 so it can measure how much you have/don't have in the exhaust.
I was researching PTFE miniature filters (don't ask...lol) a long time ago and stumbled upon their use in 02 sensors for this.
#37
The sensor won't be too cold. They are heated on their own and will regulate the temperature. Personally I think the Bosch wideband sensors are junk and always have been. I would be interested to see the life span of an NTK wideband versus the Bosch. The NTK's can be purchased with the NGK AFX wideband kit and in my opinion is the best on the market. I don't base any of this on experience with marine equipment, but 10 years of experience running them in standalone fuel injected cars used for drag racing.
#38
I can see how the O2 extension could really effect your readings. If that piece works the way I understand it from the picture I dont think you wouId get much flow over the sensor. I dont know much about O2 sensors but I think they like to have the exhaust flowing around them to be accurate.
After seeing the drawing there and seeing exactly where/how the sensor is going to be installed I highly doubt its going to work. At WOT theres going to be so much water flying around behind the transom I dont think it will last long at all.
We were using an NGK AFX wideband FWIW.
And yes, they are self heating sensors.
#39
1 Post
Fixx, did you have the sensor outside the exhaust pipe, or did you actually locate the sensor up inside of the exhaust? I thought he meant the latter when I first read this, now I realize that he is simply trying to channel the exhaust through the pipe to the outside of the tip, where the sensor would actually be located. I can't see how this would be any hotter than having the sensor screwed into a bung in the exhaust, especially with water mixing around the outside of the tube.
Am I on the right track with this, hadley, or am I off base? Are you talking about something like this?
#40
I really think that if you keep the tail of the pipe out of the exhaust stream where the water is it should work, no sharp bends and keep it as short as possible . If it works you're a hero to many in the same ...... boat!
good luck
good luck
