Baffled by apparent reversion issues with Lightning headers and mild cam >
Old 06-03-2014 | 10:02 AM
To add to the problem, that silent choice is a reversion cluster waiting to happen. Looks like you have been running it straight so far, but just keep in mind issues might arise when you are idling with silent choice on...
Did jan recommend modifying your headers for "reduced water"?
Borgie is offline
Old 06-03-2014 | 10:11 AM
Borg, I'm running it now with the straight non-SC collectors and getting the same reversion. And no, Jan (assuming the guy I talked to at Lightning) did not recommend modifying them. He did recommend using silicone in the connection joint, which I was going to test before my spark plug cross-thread cluster reared its head.
Here is a picture of it showing the regular collectors. I also have some close-ups posted further up this thread.
Budman II is offline
Old 06-03-2014 | 01:01 PM
Are you running a thermostat? my 509 had reversion issues when running on the hose and was very, very cold....it would not warm up without a thermostat. It was so bad that touching the carb was like touching an ice cube... the intake was covered in sweat as well as the risers.... freezing! this was in 70* florida weather with high humidity..... run a thermo and get some heat in the engine and see what happens?? I ended up getting some taller risers and using a thermostat at the same time and no more reversion....
tpabayflyer is offline
Old 06-03-2014 | 01:20 PM
Yeah total brain fart on my end
This is assuming it's truly reversion and not condensation... Ask to speak with Jan direct next time you dial up Lightning.
Borgie is offline
Old 06-03-2014 | 02:15 PM
Borg, I'm not sure how I could convert it to dry with the SC and not burn up the actuators. Those pipes would get really hot with no water going through them. Would need at least a spritz of water in there. Now I have considered installing some type of dump and sending most of the water down the Y-pipe, but I would still need a little bit in there to keep from melting hoses, flappers, actuators, etc.
It's just amazing that I am even having to talk about this. It's not like I'm running some monster cam with 260* @ .050 and 112 LSA. I guess it's just how I roll, having clusters that no one has ever seen before.
Old 06-03-2014 | 04:19 PM
I thought some clarification on my cam choice might be in order. Bob M. had a customer call who was interested in having him spec a cam for him and was worried about reversion. Before anyone gets the wrong idea, I should make it clear that while this is one of Bob's custom cams, it was NOT originally ground for this application, so Bob has no part in the reversion issues with this setup. I purchased this cam from another OSO member who was running the identical cam in his 509 with good results, and the mild specs led me to believe that it would be a good choice for a silent choice setup. In fact, Bob sounded the warning (after I had already bought the cam) that he could not guarantee that this cam would not cause reversion with SC. If I had it do do over again, I would have just had Bob spec a cam for me from square one, but I kind of backed into this build. It was the classic case of one thing leading to another, instead of planning everything out from the start.
Old 06-03-2014 | 04:31 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Hey Budman II , your honesty is to be commended . Good karma on you !! Black cloud be gone.............
the deep is offline
Old 06-03-2014 | 04:33 PM
If I were you I would
1. Sell the lightnings
2. Ditch the silent choice you have
3. Run dry exhaust(no more reversion BS)
Just my two cents
Borgie is offline
Old 06-03-2014 | 04:36 PM
the deep's Avatar
Fast Singles Club
http://www.diamondperformanceparts.c...cat=282&page=1
the deep is offline
Old 06-03-2014 | 04:43 PM
Just my two cents
4. Sell the whole ball of wax and buy a bow rider. Seriously, this thing is driving me to that point!
Seriously, there are hundreds of people running Lightnings with WAY more aggressive cams than this. Friend of mine is running them on an HP500 with no issues - has had them on there for 10 years. Maybe I'm just cursed.
Dry exhaust would be great to make everyone jump out of the water when it lights off , but it would get old in a hurry when I want to go for a cruise and people actually want to carry on a conversation.
That said, I really appreciate all the help and suggestions from you guys.
