over cam'd motor or pump problem? >
Old 06-25-2014 | 09:35 AM
SB
A propeller will spin fast with more hp....unless the load against the motor will not let it do so, ie: the boat itself just does not want to move any faster.
Impeller's are totally different. They are more like a torque converter or better yet, a water brake on a dyno.
That's all I know. Absolutely no jet experience what so ever other than reading basics on them.
SB is offline
Old 09-28-2014 | 09:24 AM
well its been a long time and i have an update. i found out during my trip that my impeller was F'd. in swift water it was cavitating. thats not the main issue though. so i had no clue where to begin to solve my cavitation problem. was in the impeller, stator, other. i had no idea where to start.
the impeller was just worked on so it should have been good. i had that low RPM at WOT issue because the motor wasnt making enough power etc. so i was able to get 2 different impellers to test yesterday. i found one 2 sizes down and the same one i have. the downsized impeller allowed my boat to turn 4800-4900. i havent looked at the datalogs to get exact. in the whitewater once it unloaded i was screwed. it didnt have enough push to get my boat going in the right direction once unloaded. i also got to try the same pitched one as i currently have. i just did a speed run to see what RPM it would run. it ran exactly the same as my F'd up one. you could feel the difference in push though. so it appears i need the one in between these two.
1 2 NV is offline
Old 09-28-2014 | 07:12 PM
GPM
If you actually knew where the cam was placed in the motor, you might try advancing it another 4 degrees before changing it. By doing so you will lower the power range by several hundred rpm without losing your peak HP.
GPM is online now
Old 09-28-2014 | 07:34 PM
Scarab28's Avatar
I'd try running a "C" impeller. Jets like big block torque.
Scarab28 is offline
Old 09-29-2014 | 12:02 AM
i cant remember where the cam was installed. i think it was installed exactly as need be which was advanced.
its a hamilton pump, not a berkley, american turbine or scott.
1 2 NV is offline
Old 09-29-2014 | 04:23 PM
GPM
If you didn't use a degree wheel it's impossible to tell. Lining up timing marks doesn't mean it's right.
GPM is online now
Old 09-29-2014 | 05:03 PM
On my motorcycle engines I've found the cam timing marks to be off by as much as 4 degrees.
Baja Rooster is offline
Old 09-29-2014 | 06:46 PM
my builder put it in. not me.
1 2 NV is offline
Old 09-29-2014 | 08:00 PM
talk to Duane at hi-tech performance he is the best in the country when it comes to pumps. I've worked with him for years. He can steer you properly
tunertech is offline
