Help Please!!!!  88 Four Winns Liberator 211   is SLOW!! >
Old 06-24-2014 | 07:33 AM
Default Help Please!!!! 88 Four Winns Liberator 211 is SLOW!!
Hi, I have a 88 Four Winns Liberator 211 with a 350 omc cobra drive. (Says king cobra on the hydraulic arms but doesnt have the distinct hump) A few years back when I originally purchased the boat it would run around 4600rpm-4700rpm at 57mph using a 14x3/4 x 21 SST stainless prop. Now on a freshly built motor running tbe same prop im only getting 4400rpm at 48mph. This is quite frusterating, and it comes out of the hole the same which I think it has a good hole shot. I talked to my engine builder and he said I should be able to run around 4700rpm-4800rpm. Below is some more info on my set-up if at all interested. The outdrive was rebuilt 2 years ago with the heavy duty gears, stock ratio still.
On a tired motor last summer I got a good deal on a weiand 142 blower and decided to put it on, knowing my motor was tired, I knew it wouldnt last long. After a couple hard test runs with the blower I blew a head gasket. I pulled the motor and had it mildly built by a well known local engine builder. Its bored 30over, has a mild cam that matches my edelbrock aluminum heads and intake, msd distributor and coil along with a new edelbrock 600 carb topped with a marine k&n air filter. Timing is set at 12º advanced and 37º total timing.
Thank you for your time and I'm looking forward to your suggestions
Kylep0112 is offline
Old 06-24-2014 | 07:43 AM
Speed gps or dreamometer? Tach accurate? Something is off with numbers. What's the prop pitch? 14 3/4 would be diameter. 19 or 21 is likely pitch. What is drive ratio? Was motor dynoed?
Crude Intentions is offline
Old 06-24-2014 | 07:51 AM
Speed was on a handheld Garmin GPS, I am unsure if the tach is accurate, prop pitch is 21. I am unsure of drive ratio, I am thinking the stock ratio is 1.43:1 if I recall. Motor was not dynoed
Old 06-24-2014 | 08:04 AM
Rookie's Avatar
I would be asking my builder where is my power. Do you still have the blower on?
Rookie is offline
Old 06-24-2014 | 08:27 AM
I sold the blower after I blew the head gaskets.... My family has known the guy who built my motor for 20+ yrs, he assures me that it is built properly for marine application. He has came out and checked it over, double checked timing, it has 1 gallon of race fuel to 10 gallons of super premium ethanol free fuel
Old 06-24-2014 | 08:42 AM
Where can you get "super premium ethanol free fuel" in west michigan?
Old Navy is offline
Old 06-24-2014 | 08:49 AM
There is a Citgo about 5 miles from my work, they are the only place that offers Super Premium Ethanol Free fuel.
http://citgo.mycstore.com/13697012
it is a little mom/pop little full service station, LOVE IT!!
Old 06-24-2014 | 08:50 AM
http://www.fourwinns.com/upload/Docu...Facts_1988.pdf
Page 52 shows 46-48mph for this boat with a 270 horse 350. Just a reference.
Mr Maine is offline
Old 06-24-2014 | 09:07 AM
That is an awesome manual, thank you for posting that. I know for a fact that this boat would go 57mph consistantly on my garmin gps
Old 06-24-2014 | 09:26 AM
Rookie's Avatar
Can you post the specs of the build cam/compression/heads?
There are some very knowledgeable folks on this board and can give a basic HP correlation. Then they can determine if you have
more or less power for comparison.
Rookie is offline
