trs to speedmaster >
trs to speedmaster
trs to speedmaster
Old 06-30-2014 | 08:14 PM
bigboat28's Avatar
Default trs to speedmaster
What needs to be done to go from trs to a speedmaster III. Will the transom have to be recut or is cut out the same? Will the transom have to be filled? How much does it usually cost to fill a transom drive cut out and recut it? Thanks
bigboat28 is offline
Old 06-30-2014 | 08:24 PM
Cut transom, swap TRS tailstock for a SSM tailstock on trans, move engines back a few inches.....
MILD THUNDER is offline
Old 06-30-2014 | 08:28 PM
bigboat28's Avatar
Will the transom hole from the trs need filled first or just need some more cutting?
Old 06-30-2014 | 08:49 PM
The SSM cutout is bigger I am pretty sure. You would want to plug the old mounting holes from the TRS though. My boat was a TRS boat originally, now has SSM drives, but that was done prior to me owning it. Couple buddies older cigs were converted too back in the day.
Old 07-01-2014 | 05:39 AM
Different shape cut out. Better off filling and recut. You can use a new transom gasket as a template
Unlimited jd is offline
