wiring help
Old 07-05-2014 | 04:18 PM
Default wiring help
Replacing engines and found a scare connector next to the engine wiring plug. I have a hunch its for my trim. any help would be great. Attached a photo.
[IMG][/IMG]
intimid8 is offline
Old 07-06-2014 | 01:21 AM
bump.
intimid8 is offline
Old 07-06-2014 | 08:31 AM
mrquad1's Avatar
looks like the connector for corsa exhaust,it goes to the solinoids
mrquad1 is offline
Old 07-07-2014 | 01:52 AM
It could be but I could only find the pneumatic air tubes leading up to the silent choice.. Its on both sides where the engine connector is.
intimid8 is offline
Old 07-07-2014 | 07:13 AM
Are they mpi motors? If so that plug I believe is the one that links both engines together so they both go into limp mode together. It's usually a yellow wire goes from one engine to the other.
Unlimited jd is offline
Old 07-07-2014 | 07:32 AM
Yes they are MPi. When I was tracing them back they had already been cut by the previous owner It seems. Motors are gen v's so I don't even think they had limp mode..
intimid8 is offline
Old 07-08-2014 | 07:34 AM
Anyone have any other ideas?
intimid8 is offline
Old 07-12-2014 | 01:07 PM
any feedback would be great
intimid8 is offline
Old 07-12-2014 | 01:25 PM
BUP
Year model / boat and model and info about your engines plus the engine serial #'s really could help getting some feedback. Yes you have a mercruiser cannon plug but really would help if other info is known about your app maybe to possible pin point what the connector is used for...
BUP is offline
Old 07-12-2014 | 02:42 PM
what color wires go into connector
motor is offline
