Measuring Compression Ratio >
Old 07-29-2014 | 08:26 AM
Default Measuring Compression Ratio
Is there anyway to measure the compression ratio of a motor that is fully assembled, besides taking it apart?
Satisfaction is offline
Old 07-29-2014 | 08:35 AM
if you do not know the specs on the components the answer is no.
mike tkach is offline
Old 07-29-2014 | 08:49 AM
Thanks Mike!
Old 07-29-2014 | 09:37 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Yep as said, specs ( CC's of head, piston dish or dome, deck height ect ) Good luck
John jr
Fenderjack is offline
Old 07-29-2014 | 10:44 AM
SB
Just say 10:1. That's what everyone says when they don't know. LOL.
SB is offline
Old 07-30-2014 | 12:33 PM
Yes,
http://store.katechengines.com/whist...ster-p174.aspx
You'll have to find a local shop that has one.
Jeff
hallj is offline
Old 07-30-2014 | 09:03 PM
Originally Posted by hallj
Yes,
Jeff
wow,never seen one of those.i cant see to many shops spending that on one when most engines taken to a machine shop will soon be torn down anyway.
Old 07-30-2014 | 09:26 PM
rmbuilder's Avatar
MarineKinetics
Mike,
They are utilized mainly by sanctioning body tech inspectors to verify the legality of compression limited class engines.
Bob
rmbuilder is offline
Old 07-30-2014 | 09:42 PM
if you have done enough engines and know the cranking compression of similar engine specs you can kinda guess..example my suburban is a 8:0 to 1 compression and my cranking psi is around 130.. my boat is 10; to 1 and its around 165 psi..
FIXX is offline
Old 07-30-2014 | 09:48 PM
Originally Posted by rmbuilder
Mike,
Bob
i can see a tool like that being useful for that.
