Fuel feed issues >
Fuel feed issues
Fuel feed issues
Old 08-21-2014 | 12:26 PM
Is this motor N/A pr blown ?
MILD THUNDER is offline
Old 08-21-2014 | 01:59 PM
Na
JRider is offline
Old 08-21-2014 | 02:58 PM
F-2 Speedy's Avatar
Please explain the 684 HP / hair dryer ??
F-2 Speedy is online now
Old 08-21-2014 | 08:42 PM
What do you mean? I just posted N/A...
Jim Valako Dart Race heads matched with intake...he is no joke. There are many here on oso to verify. Not sure why you are even going here.
JRider is offline
Old 08-21-2014 | 10:49 PM
Just went thru this today on my 555 NA motors. -8 or 1/2 from the tank to pump, -6 the rest of the way. 8 lbs fuel pressure at idle per electric guage on fuel dist. line. Your pressure seems low from what I have seen in the past.
As far as your HP goes, 684 NA isnt that crazy to achieve IMO. I get the 509cid limiting factor however I m sure the heads and intake make up a bunch. What carb and compression are you at?
endeavor1 is offline
Old 08-21-2014 | 11:14 PM
Get your azz in bed, we've got a hard day in front of us tomorrow.
payuppsucker is offline
Old 08-21-2014 | 11:28 PM
Had to replace my fuel line on bone stock 502 this summer and it was 5\8 or an 10.
your fuel line is probably way undersized, and or pump worn.
edit in tank to low pressure pump
buck35 is offline
Old 08-21-2014 | 11:32 PM
I'm still in Blytheville running crews. Prob won't be home till 2 or 3am. Up at 6 and back to work on the boat though.
Old 08-22-2014 | 05:38 AM
F-2 Speedy's Avatar
Im not knocking on the motor or the builder, those are great numbers for a single carb and no help.
Old 08-22-2014 | 05:57 AM
Is there a reasonably priced pump that will support my HP level? It is Gen6 sea pump mounted.
http://www.cvproducts.com/ProdDet.aspx?PN=SPIN-MP-2630
JRider is offline
