The Blower Shop Intercoolers  WTF!!! >
Old 09-25-2014 | 11:50 AM
  #31
Originally Posted by MILD THUNDER
Considering my blowers are at 7% under driven , probably not much. Unless of course I crank the boost up. But I'm not into a engine that makes 550hp on motor , and trying to make 950hp out of it via boost. Doesn't work out real well if your looking for an endurance marine engine.
Got it. So intercoolers are really only needed for blowers that are overdriven or inefficient blowers?
Pokher Ace is offline
Old 09-25-2014 | 11:59 AM
  #32
The intercooler makers claim 75 to 150 Hp gain. A few years back a buddy of mines motors dynoed at 605 ish without coolers and 698 with. So I believe they do help. They look really cool also. LOL Besides my boat is all plumbed for coolers with dumps, high pressure release dump, separate pickups, billet sea strainers and all SS braided lines. Would hate not to use all that bling!!
Likefastboats is offline
Old 09-25-2014 | 12:03 PM
  #33
Tell us more about the build that gained almost 100hp from adding an intercooler ? I'm gonna guess at 605hp it was a small blower and low boost. Then intercooler added and they turned up the boost. I'd find 90+ hp by bolting the intercooler on with no other changes , a bit hard to believe.
MILD THUNDER is offline
  #34
My engines are 7% overdriven so my intake temps are much higher.
Old 09-25-2014 | 12:04 PM
  #35
What temps are you seeing at wot
Old 09-25-2014 | 12:05 PM
  #36
Just an FYI from experience. AN stuff doesn't hold up well to raw water either.
Black Baja is offline
Old 09-25-2014 | 12:06 PM
  #37
Yes B&M 250 blowers. Yes boost was raised from 5 to 7 psi to make up for the flow restriction of the coolers.
Old 09-25-2014 | 12:09 PM
  #38
Figured as much. The majority of the gains he saw was from the extra 2psi in the manifold , and some from the cooler air temp. That 250 was prob 75 percent overdriven and making some good heat
Old 09-25-2014 | 12:11 PM
  #39
Well my guages are old and not sure how accurate but around 150 to 170 degrees.
Old 09-25-2014 | 12:38 PM
  #40
Correct me if I'm wrong but from what I have read and heard the HP gain from intercoolers is not as important as reduced combustion chamder temps, thus increasing motor longevity and less chance of detonation.
