SBC cylinder head opinions.. >
Old 08-28-2002 | 10:29 AM
traviss's Avatar
Default SBC cylinder head opinions..
Well time has come to start thinking of what to do to my 383 next.. in a month or two it comes out.. because of my income I have to start buying parts or i'll be broke by spring. What i am thinking is trying to get 475-500hp outta this motor. The short block is built to take it and high RPM too. I don't want to spin it any faster then 5500 because of the alpha ( yes it is still alive and kickin) right now I am at 5300 rpm. i think the major player for HP is gonna be cylinder heads. I have vortec ones right now with 170 cc intake ports, 222/230 dur. .543/.563 lift on a 112 LSA roller cam.. 9.9:1 comp ratio Which cylinder head is gonna be my best bet for making this kind of hp? DART, EDELBROCK, CANFIELD, ect..
How much intake CC's can a 383 support without being to much for the motor?
Thanks. i'll be back in the morning to see what you guys came up with because i have to use my moms puter at work cause mine blew up..
Travis
traviss is offline
Old 08-28-2002 | 11:14 AM
rws's Avatar
rws
I am Running Ported Dart Pro-One's 200 cc intake runners / Edelbrock Victor JR single plane intake. .625 int .631 ex [email protected] 112 cl 9.5 to one comp.
Rob
rws is offline
Old 08-28-2002 | 11:49 AM
turbo2256
Depends; if your going to stick with that cam porting your stock heads would be the best bang for the buck. After market heads
dont have as much port velosity at low lift due to there larger port volume.
Old 08-28-2002 | 11:54 AM
turbo2256
Oh if you must Brodex or Canfield would be my choice
Old 08-28-2002 | 11:56 AM
Official OSO boat whore
My advice would comes as a 250.
Cord is offline
Old 08-28-2002 | 12:15 PM
Travis,
I do not know if this helps but I have a pair of Bowtie heads sitting in my basement real cheap.Thay have a bout five hours on them.They are the 034 cating with the 1.6 2.02 valves.Let me know if you are intersted they are collecting dust.
Fishead
fishead is offline
Old 08-28-2002 | 04:37 PM
ForrestC's Avatar
Dart Iron Eagle with 200 cc intake runnners work really well on a 383 / 5000 RPM stroker motor. Go with iron heads if you cool with raw water, especially salt water.
ForrestC is offline
Old 08-28-2002 | 05:08 PM
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1852489966
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1853637915
Cord is offline
Old 08-28-2002 | 05:13 PM
TomZ's Avatar
You may make more horsepower with different heads but low rpm performance may start to take a big hit. I really think that in the RPM range you're turning it, increases in port size may not do much to help increase power.
Leave the heads alone and put a blower on it instead. You won't need to spin it faster (maybe a couple hundred RPM due to the increased air movement of the blower) and it should make a LOT of horsepower with minimal boost. You could pick up the blower kit from Summit for under $2400 I believe.
If you want to be able to take advantage of a better cylinder head, I'd suggest going up in displacement in order to provide good torque down deep in the RPM range (Car Craft or Hot Rod is working on a 454 small block... but that would be big money).
TomZ is offline
Old 08-29-2002 | 08:32 AM
turbo2256
A blower and porting stock heads would be the way to go would give you more power at less boost keep the cam on the mild side lots of good reliable power at low RPM.
