Kaama Question? >
Kaama Question?
Kaama Question?
Old 11-08-2014 | 02:15 PM
  #31
Originally Posted by soggy bottom
I am looking at a boat that has them, and was told that they are 18% overdrive with 23 P props, and have seen gears as low as 13% underdrive, so do they perform better with more prop pitch, or more gear with less prop pitch?
Dean
IMHO more pitch and diameter. I thought 1to1 was stronger than a overdrive or an underdrive setup. I only had the straightup gears I never ran one any other way.
Car Biz is offline
Old 11-09-2014 | 07:38 AM
  #32
Originally Posted by I'CE
John, are you running 8% or 13% over drive.?.. I have a transom assembly if you want to come take a look.
They are 1:1
Would like that. Where are you located again?
Kaama302 is offline
Old 11-10-2014 | 10:57 AM
  #33
If anyone has a set of 13% gears laying around, I'm always looking for spares.
CDShack is offline
Old 12-30-2014 | 12:20 AM
  #34
Originally Posted by Kaama302
They are 1:1
north reading, ma .. want me to call u?
I'CE is offline
Old 12-30-2014 | 12:22 AM
  #35
CD will look around if your still interested
I'CE is offline
Old 01-05-2015 | 02:42 PM
  #36
Appreciate it! Always looking for spares!
CDShack is offline
Old 01-05-2015 | 09:23 PM
  #37
I could use a transom assy also, mine spun a bearing and bent the small shaft
KAAMASCARAB is offline
Old 01-06-2015 | 04:23 PM
  #38
Did it mess up the casting? Small shafts are easy for a machine shop to make.
CDShack is offline
Old 01-07-2015 | 08:11 PM
  #39
It didn't help the housing, the new bearing is loose not press fit. I was going to maybe use Loctite bearing mount to glue it in, but don't know if that will work
Old 01-08-2015 | 04:31 PM
  #40
If it's pretty snug, I think I'd red locite that dude in there, see what happens.
If it's pretty sloppy, might get a machine shop to machine out the housing and build a "sleeve" to go back in the hole, like seats in heads. Recollection is that boss if pretty thin though.
Had a machine shop chrome my prop shaft and turn it down to fit when I a spun bearing. IF you have a good machine shop around, might just run it over there and see what they think they can do.
CDShack is offline
