Bearing clearances, oil weight, and more... >
Old 11-16-2014 | 08:25 AM
  #31
Originally Posted by SB
We talking just engines, a certain part or parts of engines, or complete 50's / 60's vehicle vs complete 2010's vehicle ?
BTW: Always love the Darin Morgan info. He's one of my fav's to study and thus of course quote.
I found it interesting that they run a hair looser on clearances than the norm with 0w50 oil I'm guessing Mobil 1 by his comments.
Black Baja is offline
Old 11-16-2014 | 09:25 AM
  #32
Originally Posted by the deep
I have seen these roller cam bearings used in dirt track engines because of the high valve spring pressures they run . A concept that would render this conversation moot if they were available to replace the other bearings in high HP apps. . http://www.summitracing.com/parts/cc...O7waAm2G8P8HAQ
remember way back in the 50's,,mercedes benz did a full roller motor in their gull wing.they're noisier but in our case,,who's gonna hear it.
sutphen 30 is offline
Old 11-16-2014 | 09:28 AM
  #33
Originally Posted by donzi matt
So you think a car from 1964 will have equal power, economy, interior room, and safety as a car today? Interesting.
room probably,they were boats,,everything else,,no
Old 11-16-2014 | 09:30 AM
  #34
thin oils are for dumb neighbors wives that get in their mercedes and from a dead cold start,,floor it up my street to her country club.I'm amazed that car hasn't blown up.
Old 11-16-2014 | 09:50 AM
  #35
Full Force's Avatar
I get so pissed at the wife when she dont let Mountaineer run for a few before driving, HUGE pet peeve
Full Force is offline
Old 11-16-2014 | 11:55 AM
  #36
OMG, I can remember back when I was a kid, mom would start our brand new 1977 Cadi, at 10 below zero, had a 501 in it, and rev the **** out of it till it warmed up. The motor would make noises that, even as a kid, I knew were bad. Well I think back then they had 10W 30 oil in that motor, & its a good thing dad got her a new one every year... LOL
Bawana is offline
Old 11-16-2014 | 12:12 PM
  #37
Originally Posted by Black Baja
Darin Morgan
Show Guest
Posted: Sat Mar 04, 2006 10:01 pm Post subject: Re: help with switching to 0-30w oil
seth wrote:
when switching from a 20-50w to a 0-30w oil do you need to tighten up the clearances. I have tried 0-30w oils in the past with limited sucess. if i run .001" per inch of dia. as my oil clearance do i need to tighten that up and how much as a rule.
amsoil racing oil 20-50w and switched to their 0-30w bearing life has been shortend drastically.
as of now i'm not sold on the 0-30w
If your having bearing problems with 05-30W synthetic oils your problems are not with the oil as much as they are the clearances and the machine work. Bearing misalignment or worse yet, to tight a clearance will hurt you every time. A good line honed main and properly trued and honed rod housing bores seem like a given but they seldom are. They need to be addressed, checked out and honed by a professional that knows what he is doing. You need to have .003 on the rods and .0035 on the mains or your playing with fire. We run .003+ on the rods at all times never less than that, ever. We run .0035 to .00375 on the mains and never less than that, ever. On engines with higher loads the clearances go up never down. Pin bores can have up to .00225 for clearance on some engines with high vacuum in the crank case and good oil control in the pan. The better the oil control and vacuum in the pan, the less oil the wrist pins get! We run 0055 (not a misprint) weight and it about the thickness of water. we run .0035 on the rods and upwards to.004 on the mains in the PS engines and the mains last all year long. Our 1300 horsepower Super Series engines have .003 rods and .0035 mains and run for 600 runs down the track! The record so far is 675 runs by Scotty Richardson.
(1) Get a good, professional machinist to line hone the mains and hone the rods properly.
(2) Make sure you have proper oiling. If your pressure fluctuates during the run,, you have problems.
(3) .003 rods and .0035 mains for clearance
(4) Use a good synthetic 05-30w oil like Mobil-1 or Castrol syntec
(5) In my personal opinion you need to stop using any oil from Amsoil. That is not a racing oil even if they say it is.
_________________
Darin Morgan
while i think darin morgan is a sharp guy i disagree with his dislike of amsoil products.i would like to see factual information on the problem,s with amsoil.i personally think amsoil is good stuff and testing of there products has proved that.
mike tkach is offline
Old 11-16-2014 | 12:26 PM
  #38
I'm with you Mike. He's not a builder but he is at the forefront of making horsepower. I know he's one of these kind of guys if you port a set of heads and he ports the same head and your head flows 2 Cfm less then your head is a POS. just thinking out loud maybe amsoil makes 5 less horsepower than something else. If that's the case I'm sure it's a POS to him. When your doing Pro Stock stuff every little last but of power counts. Most of us in the boating world have experienced the Amsoil results especially in the bravo drive. But to a guy like him if you put Mobil 1 in the drive and the boat is 1mph faster Amsoil is a POS.
Old 11-19-2014 | 02:22 PM
  #39
I would wonder if I should run tighter Clarence's in a motor that I'm building that will be all forged lower end, have a ProCharger at 8-10psi and never break a water temp of 100°F then say a similar motor that warms up to 200° and stays there. My motor running so cold may not expand as much.. For cooling the bearings, I like the idea of a little lost with a heavier oil "VR1,20-50" and a bigger oil pump.. As for load/vers oil viscosity, I'm not sure.. My cat engines in my OTR semi trucks have a high load, slow rpm deal and run 60-80 psi oil press with 15-40 but the otr Cummins isx engine maybe make 30 psi hot. My new Volvo runs 10-30 summer, 0-30 winter. Not quite a boat motor tho.
Fordtrucks is offline
Old 11-19-2014 | 02:26 PM
  #40
Running an engine hard when it's cold is no good. You also need to get the temp up enough to release any condensed water. Additionally, water temp and oil temp are two completely different things. Tight clearances, thick oil, and a big pump is not a smart move.
Quick2500 is offline
