Removing Silent Choice Exhaust ??? >
Old 11-29-2014 | 05:42 PM
Default Removing Silent Choice Exhaust ???
I would like to remove the Silent Choice from the rear two engines on my 47 Fountain (the center engine does not have it). My question is can I just remove the upper pipes that contain the diverters and cap the cast pipes coming from the drive or do I need to remove the entire assembly and cap them off down below, I'm assuming the latter requires the engine to be pulled. See pics of my setup...
[ATTACH=CONFIG]533430[/ATTACH][ATTACH=CONFIG]533431[/ATTACH][ATTACH=CONFIG]533432[/ATTACH][ATTACH=CONFIG]533433[/ATTACH]
Attached Thumbnails Removing Silent Choice Exhaust ???-photo-1-2.jpg   Removing Silent Choice Exhaust ???-photo-2-2.jpg   Removing Silent Choice Exhaust ???-photo-3-1.jpg
HyFive578 is offline
Old 11-29-2014 | 05:46 PM
I've capped the cast Y pipes with no issues. Preferred method would be removal though.
endeavor1 is offline
Old 11-29-2014 | 06:33 PM
What did you cap them with ??
Old 11-29-2014 | 06:39 PM
I've seen in pictures, not in person, expandable pipe plugs. They sell them at hardware stores.
Jonesyfxr is offline
May I ask why would you want to do that? Besides the noise- there is somewhat of performance benefit -- it lets the engine breath a little better? I know that I get just about 3 mph opening the exhaust up.
3pointstar
3pointstar is offline
Old 11-29-2014 | 08:51 PM
This is how my boat came to me. I have too much cam to run them, and have heard of a few OEM motors sucking in water when a flapper fails, but I'm no expert on the subject.
Baja Rooster is offline
Old 11-29-2014 | 09:19 PM
I've seen guys use ripper pipe plugs. I used fiberglass molds that were the same oblong shape as the Y pipe. I bought them from Envision boats years ago.
Old 11-30-2014 | 06:37 AM
I believe you can buy y pipe cap off plugs from Keith Eickert performance. I was looking into doing that when I was having issues getting my silent choice to work with my headers.
yup, you can
http://www.keitheickert.com/p-12573-...sert-caps.aspx
halfgassed is offline
Old 11-30-2014 | 06:53 AM
3pointstar
I have some evidence of reversion on the back two motors. The tails are very short and the 525 cam is pretty aggressive. I am going to be modifying the tails to have the water exit at the tip outside the boat. I never use the Silent Choice anyway and there are some (including Merc) that suggest that the Silent Choice can contribute to reversion on the 525. Just trying to do whatever I can to minimize those possibilities.
Old 11-30-2014 | 07:28 AM
HyFive 578
Thanks for the insight - my engine 7.4mpi is all stock and I've never had a problem with reversion in any way. Take care and good luck
3pointstar
