Favorite BBC Rod Thread >
Old 12-10-2014 | 02:20 PM
  #91
MER Performance's Avatar
I was trying to digest; Full Forces, build here. I just finished off 10 oz of magnesium citrate, lets see what happens.
MER Performance is offline
Old 12-10-2014 | 02:30 PM
  #92
Full Force's Avatar
Originally Posted by MER Performance
Running a 4.375 stroke, 6.385 rod CH of 1.270 would take you .042 out of the hole. If you had a .050 thick gasket the piston would rock and hit. Someone machined pistons down, either a custom piston would be needed or use a 6.535 rod with custom piston having a 1.077 C.H. I'm pretty sure the ring stack would work being its a NA build. I have no idea how you, can swing that piston and rod length around that counter weight unless, you machined down counter weights.
Not the best combination for a 4.375 crank in a 9.800 deck block
Oh the pistons were ever so slightly touching the heads... Inwill post pics when I get home same as his hack grinding on crank I would assume from hitting pistons... I never seen such a cluster fuk build before I wish I would have never bought the scarab to get em!
Full Force is offline
Old 12-10-2014 | 02:33 PM
  #93
Knot 4 Me's Avatar
I'm surpised they didn't clatter like a diesel!!
Knot 4 Me is offline
Old 12-10-2014 | 02:42 PM
  #94
That there is the reason the rod bearings failed ! The hydrodynamic wedge of oil was lost, you just can't pull a piston, down on top of a counter weight.
Old 12-10-2014 | 02:44 PM
  #95
That mess can be corrected, without, throwing it all in the trash.
Old 12-10-2014 | 03:02 PM
  #96
Full Force's Avatar
I am selling off old stuff and doing all new 540's local engine builder does matching my buddy and I will assemble and all issues will be gone... I can't wait!
Old 12-10-2014 | 03:31 PM
  #97
Thats why machining is so critical in engine building. People often forget that and focus on "the parts" .
Looks like "Goober with the green teeth" assembled yours. That would have to be very noticeable when hand turning that when first put together.
Wannabe
wannabe is offline
Old 12-10-2014 | 04:55 PM
  #98
Full Force's Avatar
Wannabe
here are some pics of the hackwork, I dont wanna clog this thread up with my mess, so here's the thread I have on it from when it happened...http://www.offshoreonly.com/forums/g...tml?highlight=
[ATTACH=CONFIG]534109[/ATTACH][ATTACH=CONFIG]534110[/ATTACH][ATTACH=CONFIG]534111[/ATTACH][ATTACH=CONFIG]534112[/ATTACH][ATTACH=CONFIG]534113[/ATTACH][ATTACH=CONFIG]534114[/ATTACH]
Attached Thumbnails Favorite BBC Rod Thread-piston-1.jpg   Favorite BBC Rod Thread-piston-2.jpg   Favorite BBC Rod Thread-piston1.jpg
Favorite BBC Rod Thread-547-rod3.jpg   Favorite BBC Rod Thread-547-rod2.jpg   Favorite BBC Rod Thread-crank-1.jpg
Old 12-10-2014 | 04:59 PM
  #99
Wish the crank didn't need to be cut. I'd buy it. Buy I'm a picky ***** and only like std.
Unlimited jd is offline
Old 12-10-2014 | 05:01 PM
  #100
Full Force's Avatar
Thats another reason I am starting 100% over with NEW stuff...
