Low water pickup depth below bottom
I have water pressure gauges connected after the water pump. Anyone played with this - that could add a mph or two. I have heard that some boats have them less than 1/8" deep and round the front edges to draw up the water better.
Also, what is adequate water pressure??? I would guess 10-15psi. Thanks.
My pickups are rectangular shape. The bottom side that faces down, has a plate welded. It is then drilled with a bunch of small holes for water to pass thru . it filters out any debris from entering the system.
thanks for info.
Sutphen30 - it doesn't have steps.
Ya'lls info gives me a little more confidence that I will be able to take off quite a bit from the just under half inch they are now but I think best to go 1/8 at a time until I get the pressure down to 20psi or so as long as its cooling good. Hopefully may gain a couple mph if I end up at only about 1/8 deep. Will let yall know but will be a few weeks, rebuilding one motor now.
I know you don't have steps.was asking Black baja,3"'s is-really deep.only saw it like that on my friends formula.water pressure is perfect at 110mph.
Yes, stepped hull. Every boat is different when it comes to water and cooling motors. Some boats have water problems. Proper setup of a water pickup is trial and error. There is no magic formula.
have you thought about running low water pick ups and ditching the transom mount.may pick up a lot of speed.
Been there done that even tried modifying low water pickup on the drive. Nothing worked. Had a transom mount pickup right off the bottom of the hull (boxed one just like everyone else) no go. I think the steps out a lot of air in the water I was seeing 18psi with drive pickup and flush transom hull pickup. Motor would get hot. Only thing that worked was burying the pickup. I talked to a guy that has rigged a ton of boats he said sometimes you get a hull with these issues.
Its got bravo ones so if it came with the factory hose setup through the transom plate from the standard water pickups everything would be fine. Previous owners had problems with corrosion at the fitting going thru the transom plate and choking off water flow. Very common problem.
THe problem is they should have just kept it simple and corrected the corrosion issue. THen no deep scoops to drag the boat down possibly 1-3 mph, and much much less mud/sand is picked up by the the standard Bravo pickups when beaching a boat like we don around Lake Charles, La several times each day when were are out.
