Going blown have a few questions? >
Old 12-21-2014 | 09:27 PM
What size oil lines would you guys use, right now I got Aeroquip 10 an with full flow fittings everywhere is that what everybody is running. I thought about going to 12an but is this overkill
Want2gofast is offline
Old 12-21-2014 | 09:42 PM
i rig with -12 but -10 should be just fine imo.
mike tkach is offline
Old 12-21-2014 | 10:08 PM
Thanks Mike. Help is appreciated
Old 12-22-2014 | 06:19 AM
T-Mone's Avatar
T-Mone
Just what my engine builder zul wanted me to use an i have 540 w 871 we dynoed at around 1000hp pump gas no chiller. a/f # were perfect across the board. Remember bigger is not always better.
T-Mone is offline
Old 12-22-2014 | 06:20 AM
T-Mone's Avatar
T-Mone
WE run -10 oil lines make sure you have a oil thermostat also
T-Mone is offline
Old 12-22-2014 | 06:34 AM
What are the components on this build? Heads? What boost psi and blower drive ratio? Did you measure air intake temps?
Did you try a pair of 1050s on the build? Maybe you could have seen 1050 instead of 1000 and less heat in the intake manifold.
MILD THUNDER is offline
Old 12-22-2014 | 08:03 AM
Seeing as he already has the 1050's I would go with what you got.
Black Baja is offline
Old 12-22-2014 | 08:43 AM
i also would be interested in the facts on this engine.always willing to learn how some guys make stated power.
Old 12-22-2014 | 09:12 AM
I'd like even more to see the dyno sheet...
Old 12-22-2014 | 09:39 AM
4195 on the board has a pair of Zul 540's with 8-71's that made 800 with less than 5lbs of boost. Over 1000 sure would be impressive with an 8-71 and no chiller. He!! By next season in hoping to make 850-900 with a 10-71
Unlimited jd is offline
