Couple quick questions - piston install >
Old 01-03-2015 | 01:55 PM
seafordguy's Avatar
Default Couple quick questions - piston install
Couple questions:
I don't have the heads with me to check so I'm using my MK4 as a reference but it appears the relief for the intake valve in the piston is towards the rear on the 1/3/5/7 side and towards the front of the engine on the 2/4/6/8 side. Can someone confirm for me that is the case on the gen 6 as well??
Second - my connecting rods don't appear to have a chamfer on either side. Can anyone confirm that is the case with stock 502 rods?
As I said before, I've got plenty of more dumb questions to go....
seafordguy is offline
Old 01-03-2015 | 02:27 PM
seafordguy's Avatar
http://www.boatfix.com/merc/Servmanl/16/16A3R2.PDF
This says towards the center of the motor which jives with the way my mk4 is assembled
Old 01-03-2015 | 02:29 PM
You have the intake exhaust layout correct.
Exhaust is the first valve on number 1
Black Baja is offline
Old 01-03-2015 | 02:35 PM
Put a bearing in the rod and then see what you got...
Old 01-03-2015 | 02:44 PM
seafordguy's Avatar
And the exhaust doesn't need the relief which would put the relief towards the rear on 1 - am I thinking that through correctly!?!?!?!?
Old 01-03-2015 | 02:50 PM
Yes.
If you install a rod bearing in the rod you should be able to tell which end has the larger chamfer. Big chamfer goes towards crank. Small goes towards rod.
Old 01-03-2015 | 04:58 PM
seafordguy's Avatar
Okay. Let me do that and see if I notice any difference
Old 01-04-2015 | 07:30 PM
seafordguy,please don,t take this wrong but are you sure you want to start out on a bbc marine engine?i recommend you get a few books on engine building before you go any farther,you can learn a lot from them.
mike tkach is offline
Old 01-05-2015 | 06:03 AM
seafordguy's Avatar
Not taken wrong mike. I am following a couple books and read front to back a couple times before starting and taking it real slow. That's why all the questions. Just going to need some support from you guys along the way......
Old 01-05-2015 | 09:08 AM
ok,i understand and you will get plenty of help here.
