noise under valve cover
Agree about the condition of the lifer bore as to what BB said. I would think with the valve covers off and hand turning over the motor or cranking over at the ignition, a problem would have been noticeable that something was amiss in that valve train area. Just asking or did you just decide to pull the intake off and keep digging ?
I was concerned about the lifter coming out of the block and was relieved today when I was able to slide it out with absolutely no problem. The roller was rounded off on all sharp corners, but nothing was bent really bad. The oil pan has some very small metal debris in it. I have not cut the oil filter yet. I am sure that I had no change in oil pressure. I inspected the 2 cylinders closest to the failure and cannot see any scoring.
I will try to post some pics tomorrow. I really want some oppinions on if I need to hot tank or not.
Thanks to all.
FT
Thanks to all.
FT
Just wondering if anyone has ever seen this before. Spoke to Bob Madera yesterday and he said that he has seen the exact same thing happen before if using cast lifters, which is what I believe I have.
