Need Prop Help >
Need Prop Help
Need Prop Help
Old 09-05-2002 | 02:33 PM
splash n' dash
Ok, I could be wrong,the test was run last year,15 min.apart,on a gps. Now I don't know if I used a 23 or 25 rev. 4. I did get out of the hole faster,but like I said no bow lift ie slower top end. Thats the way it worked out for me. May be diferent on other boats
Old 09-05-2002 | 04:36 PM
MIKEHTMSR24's Avatar
Default I agree with ya
15 minutes apart is a good test.
I would find it hard for a 4 blade to beat a 3 blade on top end unless the 4 blade is TOO much prop (out of the reccomended rpm range.) Then you could get more mph out of a 4 blade if the pitch was too high.
From what I found out on MY boat the Rev 4 does not lift the transom as much as the Bravo's but more than the 3 blades. This is why I tell everybody to try the rev 4 first. It is a the compromise between wanting a 3 bladed for top end but love the mid range of a four blade. The only bad thing about the Rev's is the hightest pitch is 23. My stock 23 Rev 4 spun the same rpm as my labbed Bravo 1. Maybe 50 to 75 more rpm than the bravo 1.
MIKEHTMSR24 is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
