Engine Guys help (scan tool to use) on 97 454mag mpi's >
Old 01-15-2015 | 10:00 AM
Default Engine Guys help (scan tool to use) on 97 454mag mpi's
I would like to pick up a scan tool for my twin 97 454mag MPI's just to have and to make minor adjustments like to a new IAC etc..
Any recommendations without breaking the bank.. (yea I know its a boat and 10 x the cost) Any info appreciated.
silent lucidity is offline
Old 01-15-2015 | 10:04 AM
diacom
and as for resetting the iac,,it finds closed position(0) on every key on.
sutphen 30 is offline
Old 01-15-2015 | 10:13 AM
I removed my plenum and all cables etc. to have my injectors all cleaned and tested.. Was reading an article about re-setting the throttle/ idle and IAC properly once put back together. It mentioned that it was a must once all disconnected.
Old 01-16-2015 | 12:45 PM
Bump as I also have a similar question, are the diacom and rinda tools same or totally different, and if so how.
buck35 is offline
