Pushrods
Old 01-17-2015 | 10:54 AM
vintage chromoly's Avatar
Default Pushrods
Hello all.
Working on an engine project.
512 merlin block
Springs will have 195 closed and 540 open psi.
55 MM Mech roller with .700" lift.
Jesel shaft mount rocker arms.
6000 rpm max.
What size pushrods?
Diameter?
Wall thickness?
I intend to consult bob as he's providing the cam, lifters and springs but just a bit bored and doing some research.
Thanks all,
Rob
vintage chromoly is offline
Old 01-17-2015 | 11:08 AM
i have been useing the 3/8 dia pushrods with .135 wall from trend performance.they have just about any length in stock.i think bob sells a .120 wall pushrod that will be almost the same.let us know what bob sais.
mike tkach is offline
Old 01-17-2015 | 11:12 AM
Originally Posted by vintage chromoly
Hello all.
512 merlin block
6000 rpm max.
What size pushrods?
Diameter?
Wall thickness?
Thanks all,
Rob
the spring seems a little light for a solid roller.i am running that on my hyd roller 588s.
Old 01-17-2015 | 11:15 AM
Hey mike. I will post what bob says.
On a side note, the engine had a .720 lift cam and had .842 crower solid lifters and 3/8 .080 walled CV (which I believe are made by trend) pushrods in it. It had the 55MM cam and they spun it to 7500+ rpm.
Old 01-17-2015 | 11:16 AM
Springs are what Bob specified.
Old 01-17-2015 | 11:26 AM
Craney's Avatar
I got my push rods from Bob and they were Manton push rods.
Craney is offline
Old 01-17-2015 | 11:32 AM
From the research I've been doing, it appears that the diameter affects the deflection and the wall thickness affects the compression of the pushrod.
It's hard for me to imagine a pushrod being compressed but easy to imagine the delection.
Old 01-17-2015 | 11:38 AM
it stands to reason that the thicker wall would also help with the deflection.i would love to see a comparison with an .080 wall vs .135 wall on a spintron.
Old 01-17-2015 | 11:53 AM
14 apache's Avatar
I did a set up similar to that 714 lift and 195psi maybe a little lighter at 6000 worked perfect. 3/8 .080 maybe .120 wall pushrods I forgot.
How many people run the valve spring oilers not the rocker arm ones?
This was with std camshaft and .842 lifters
14 apache is offline
Old 01-17-2015 | 11:58 AM
55mm cam and larger lifter wheel doesn't need as much spring. Sorta like a gear reduction/ a lot less pressure angle.
Black Baja is offline
