-   -   Another build dyno'd today. Whippled 509. (https://www.offshoreonly.com/forums/general-q/322244-another-build-dynod-today-whippled-509-a.html)
MILD THUNDER 01-19-2015 07:48 PM
1 Attachment(s)
Another fun build that worked out real well. Mike Tkach built this one for a friend. It started out as a 502 Mag engine. Stripped down, bored to 509ci, flat top pistons installed, 2.3L carb'd whipple, with intercooler. . The owner of the engine wanted to stick with the GM rectangle ports. They did need some work, some seats were no good, etc. Anyhow, the shop went thru the heads, installed the larger 2.25 intakes, and did their valve job and bowl/pocket port cleanup. Bob M spec'd the cam for this build.
Mike and I went back and forth on this build, debating on what we thought it would make for power. Granted, him and I have never used one of these small single carb whipples before, and lets just say we underestimated it. Mike and I honestly thought this engine would maybe do around 650HP range. We were way off.
What really impressed me was the torque with this baby screw! Good lord. Anyhow, just thought I'd share it. Pretty basic build, nothing real trick. Bob nailed it on the cam as usual, and it just worked nicely.
stimleck 01-19-2015 08:19 PM
wow thats great what octane?
Full Force 01-19-2015 08:37 PM
Very impressive!!
MILD THUNDER 01-19-2015 08:44 PM
Makes me want to bolt a small whipple on my big block gas dually.
tpabayflyer 01-19-2015 09:10 PM
Wow..... That's a ton of torque for only 7psi....... Great job!
Flightplan 01-19-2015 09:20 PM
How much of this Hp is motor? What boost out of the little whipple.
TooLateVTEC 01-19-2015 09:34 PM
Is that torque for real? Holy S
Flightplan, boost is on the sheet....starts at 7 and goes down to 5.8 (third row from the right side)
Flightplan 01-19-2015 09:38 PM
Thanks. Didnt look past Hp & torque
SB 01-19-2015 09:43 PM
That 850 must have been struggling airflow wise.
buck35 01-19-2015 09:49 PM
Nice results! apparently they are pricy for good reason. Wish I could drop mine off with you two!
