standard deck to a tall deck >
Old 01-30-2015 | 11:25 AM
I saw accessories and flywheel in orig post . The flywheel will need to match your crankshaft -balance needs if your going to a gen 4 tall deck from something later then add oil pan , you will need to make sure distributor is where it needs to be in relation to your intake pad and such . Generally wont just swap out unless you have a special intake that puts dist back down in hole.crapshoot on accessories , if you have a buddy thats a good welder the exhaust will be fairly easy .you might be able to fab the riser tailpipe joint without welding , already forgot which exhaust you were running sorry
airjunky is offline
Old 01-30-2015 | 11:35 AM
There it is gil . Might be able to pull the 4 manifold studs and fab a adapter to redirect pipes back .think i remember a guy cutting out 4 pretty quick out of 3036 that put the tails back to the tips.you will need another set of gaskets
airjunky is offline
Old 01-30-2015 | 04:04 PM
bigboat28's Avatar
My motors are 35 1/4 " crank to crank and i have about 1 1/2" between inside exhaust manifolds.
bigboat28 is offline
Old 01-30-2015 | 05:07 PM
F-2 Speedy's Avatar
Is your hatch ram in the middle or outside on the ends
F-2 Speedy is offline
Old 01-30-2015 | 08:33 PM
bigboat28's Avatar
In the middle.
Old 01-31-2015 | 04:35 AM
vintage chromoly's Avatar
Build some standard deck stroker engines and save yourself a bunch of assache.
vintage chromoly is offline
Old 01-31-2015 | 04:49 AM
ROB FREEMAN's Avatar
i rhought the same . mel riggs from riggs marine had to change mine .although i wasnt there .. had to custom headers from cmi they were touching . alot of rigging issues . although it might have been because of my huge oil pans pfaff used on my new engines .. maybe that was it .. hmm i cant remember exacty what his reasoning was .. at the time dint give a chit just wanted them in ... lol
ROB FREEMAN is offline
Old 01-31-2015 | 06:26 AM
Craney's Avatar
Originally Posted by vintage chromoly
build some standard deck stroker engines and save yourself a bunch of assache.
a+
Craney is offline
Old 01-31-2015 | 07:13 AM
Also remember using different heads with raised exhaust ports will change tail location also.
KWright is offline
Old 02-01-2015 | 12:09 AM
Originally Posted by kwright
also remember using different heads with raised exhaust ports will change tail location also.
The 10.2 deck engine is going to be 2" wider at the exhaust as well.
Jeff P31 is offline
