horsepower estimate >
horsepower estimate
horsepower estimate
Old 02-03-2015 | 09:45 AM
Cmi headers
Satisfaction is offline
Old 02-03-2015 | 10:59 AM
Originally Posted by Black Baja
My guess is a lot more if you get rid of that cam that is all wrong.
Why is the cam "all wrong"?
JRider is offline
Old 02-03-2015 | 12:57 PM
your right,,why get a cam thats proven to work,,should get a real good bump stick from the worlds worst cam guy,,my buddy cslob.
sutphen 30 is offline
Old 02-03-2015 | 01:06 PM
I understand that I could make more power with a custom cam built for my specs. But at the same time I believe it could make pretty decent power with most likey the best out of the box cam.
Old 02-03-2015 | 01:13 PM
I would guess more HP and torque than a Alpha can handle.......
CrownHawg is offline
Old 02-03-2015 | 01:23 PM
I pesronally doubt it,moving the the cam degrees and calling it custom is not going to change hp all that much.you jump the cam degrees 6-10degrees,then you going against a different cam for way more hp.custom cam is going to net you anything you'll feel in a boat.
you pick a hp goal and alot of cams will get you there.
Old 02-03-2015 | 01:45 PM
rmbuilder's Avatar
MarineKinetics
With a AFR 315 head combination there is an easy 25 HP available.
rmbuilder is offline
Old 02-03-2015 | 03:07 PM
Was Straub ever mentioned?
Black Baja is offline
Old 02-03-2015 | 03:19 PM
I don't think it would be money well spent to spend all that money on a nice set of heads and put the wrong cam in the motor. Not only will it make less power on the top end. But it will be sluggish. Add a Carburetor that is entirely too big and it gets even worse.
Old 02-03-2015 | 04:04 PM
BB, I actually thought you were being sarcastic with your first post. I don't think the 741 is way out of line for this build. My only thought would be that you could make the same, or more power with a more modern lobe design that is a little easier on valve train parts. if I already had a 741 though, I'd probably run it. I'm going to guess 635 if you've got your valve train sorted.
HaxbySpeed is offline
