What's you're opinion... stroke vs. bore
#51
SO MUCH CHEAPER in the longrun to bite the bullet and do it all as once.
My machinist has a sign in his shop entry: "SPEED COSTS MONEY..........how fast do you wanna go???"
#52
#53
a bit off the OP's plans, but just for kicks ck. out the bore and stroke combination, note the rod legth too OSO ad#60249 .. like Mild said they need to be properly set up.
#54
http://www.offshoreonly.com/classifi...o60249-en.html
Thanks for sharing I'CE. It is interesting all the combos out there. Unfortunately no one has un biased proof on what works best, safestest, most power.
I don't like that combo personally..... Looks like they lowered the compression on a NA supercat combo with a blower stuck on top...
Ilmor did just merge with scorpian race engines...
#55
I like all the insight. Very entertaining. I think there's a few takeaways from this...
1) Go with the larger bore AND the larger stroke. --> "The no-brainer"
2) Bolt on a blower for more power --> Not really part of the qusstion, and completely complicates the question, but 100% agreed
3) The consensus seems to agree, all things other things considered equal --> No measurable difference
With that in mind... let's throw in a few more variables...
--Now i'm starting to get real to life--
1) Let's consider it's a retrofit hyd roller cam at about 589, 610 lift
2) Aluminum Dart Pro 1 at 310 cc
3) 800 cfm Holly vacuum secondary
4) No room for a blower (blowers are out of the question)
5) OK exhaust (aluminum manifolds with individual runners for only 12 inches)
6) Purpose is to go 60 MPH and drink heavily when I get there in a 13,000# Baja
7) The 4.25 stroke engine is around $3500 the 4.00 stroke engine is around $4000 new (same warranty)
Oh... one more variable.... I'm not going to build them bigger in the future.
GO!!!!
GO!!!!
#56
i have 454's and I'm running around 62 mph on a good day.That was before i lost a motor. Not that I really want to go much faster, its a tank. But if i had the same speed and really good reliability, I could be happy. Looking for a good smooth idle, easy starting, and reliability... and hopefully 65 MPH.
#57
#58
#59
