What's you're opinion... stroke vs. bore
#72
What about mass in the equation?? Just thinking a shorter stroke has a slower piston speed, but a larger bore requires a larger piston, therefore you a reversing direction on a larger piston..larger piston= greater mass=greater inertia
So we have longer stroke=greater piston speed=greater inertia
vs. larger bore =greater mass =greater inertia
Remembering that an object in motion will remain in motion unless acted upon leads us to the point that:
To truly determine which is most efficient we must plot on a linear basis the force required to reverse piston direction. The least amount of force required should be the most efficient. Of course it must also be determined when comparing different stroke vs. bore scenarios if this difference is linear or exponential.
Who has their slide rule handy??
#74
I understand that i was just using that in relative terms to is building a high reving big bore short stroke wasting to much energy versus big stroke low revs torque monster. Was just curious of thoughts being i dont have much experience with this debate relative to boats
#75
#78
Tech Talk #53 – Big Bore or Long Stroke: Which Is Better?
DavidTechArticlesBy David Reher, Reher-Morrison Racing Engines
“An engine produces peak torque at the rpm where it is most efficient.”
Recently I’ve had several conversations with racers who wanted to build engines with long crankshaft strokes and small cylinder bores. When I questioned them about their preference for long-stroke/small-bore engines, the common answer was that this combination makes more torque. Unfortunately that assertion doesn’t match up with my experience in building drag racing engines.
My subject is racing engines, not street motors, so I’m not concerned with torque at 2,000 rpm. In my view, if you are building an engine for maximum output at a specific displacement, such as a Comp eliminator motor, then the bores should be as big as possible and the stroke as short as possible. If you’re building an engine that’s not restricted in size, such as a heads-up Super eliminator or Quick 16 motor, then big bores are an absolute performance bargain.
I know that there are drag racers who are successful with small-bore/long-stroke engines. And I know that countless magazine articles have been written about “torque monster” motors. But before readers fire off angry e-mails to National DRAGSTER about Reher’s rantings on the back page, allow me to explain my observations on the bore vs. stroke debate.
In mechanical terms, the definition of torque is the force acting on an object that causes that object to rotate. In an internal combustion engine, the pressure produced by expanding gases acts through the pistons and connecting rods to push against the crankshaft, producing torque. The mechanical leverage is greatest at the point when the connecting rod is perpendicular to its respective crank throw; depending on the geometry of the crank, piston and rod, this typically occurs when the piston is about 80 degrees after top dead center (ATDC).
So if torque is what accelerates a race car, why don’t we use engines with 2-inch diameter cylinder bores and 6-inch long crankshaft strokes? Obviously there are other factors involved.
The first consideration is that the cylinder pressure produced by the expanding gases reaches its peak shortly after combustion begins, when the volume above the piston is still relatively small and the lever arm created by the piston, rod and crank pin is an acute angle of less than 90 degrees. Peak cylinder pressure occurs at approximately 30 degrees ATDC, and drops dramatically by the time that the rod has its maximum leverage against the crank arm. Consequently the mechanical torque advantage of a long stroke is significantly diminished by the reduced force that’s pushing against the piston when the leverage of a long crankshaft stroke is greatest.
An engine produces peak torque at the rpm where it is most efficient. Efficiency is the result of many factors, including airflow, combustion, and parasitic losses such as friction and windage. Comparing two engines with the same displacement, a long-stroke/small-bore combination is simply less efficient than a short-stroke/big-bore combination on several counts.
Big bores promote better breathing. If you compare cylinder head airflow on a small-bore test fixture and on a large-bore fixture, the bigger bore will almost invariably improve airflow due to less valve shrouding. If the goal is maximum performance, the larger bore diameter allows the installation of larger valves, which further improve power.
A short crankshaft stroke reduces parasitic losses. Ring drag is the major source of internal friction. With a shorter stroke, the pistons don’t travel as far with every revolution. The crankshaft assembly also rotates in a smaller arc so the windage is reduced. In a wet-sump engine, a shorter stroke also cuts down on oil pressure problems caused by windage and oil aeration.
The big-block Chevrolet V-8 is an example of an engine that responds positively to increases in bore diameter. The GM engineers who designed the big-block knew that its splayed valves needed room to breath; that’s why the factory machined notches in the tops of the cylinder bores on high-performance blocks. When Chevy went Can-Am racing back in the ’60s, special blocks were produced with 4.440-inch bores instead of the standard 4.250-inch diameter cylinders. There’s been a steady progression in bore diameters ever since. We’re now using 4.700-inch bores in NHRA Pro Stock, and even bigger bores in unrestricted engines.
Racers are no longer limited to production castings and the relatively small cylinder bore diameters that they dictated. Today’s aftermarket blocks are manufactured with better materials and thicker cylinder walls that make big-bore engines affordable and reliable. A sportsman drag racer can enjoy the benefits of big cylinder bores at no extra cost: a set of pistons for 4.500-inch, 4.600-inch or 4.625-inch cylinders cost virtually the same. For my money, the bigger bore is a bargain. The customer not only gets more cubic inches for the same price, but also gets better performance because the larger bores improve airflow. A big-bore engine delivers more bang for the buck.
Big bores aren’t just for big-blocks. Many aftermarket Chevy small-block V-8s now have siamesed cylinder walls that will easily accommodate 4.185-inch cylinder bores. There’s simply no reason to build a 383-cubic-inch small-block with a 4-inch bore block when you can have a 406 or 412-cubic-inch small-block for about the same money.
There are much more cost-effective ways to tailor an engine’s torque curve than to use a long stroke crank and small bore block. The intake manifold, cylinder head runner volume, and camshaft timing all have a much more significant impact on the torque curve than the stroke – and are much easier and less expensive to change.
#79
#80
I'd beg to differ on said opinion, as the stroker engine would have a slight advantage over the big bore engine, piston speed being the advantage and if you look at an engine as what it really is (a pump) you will find that the longer stroke increases the piston speed which in turn increases the air volume of said pump... beyond that of the big bore engine... however, with that being said, if you rev the BB (big bore) engine to a point that the piston speeds match then you'd have a stroker crusher!!! as that BB engine would dominate over the stroker
says the oldest student in med school!!!
